I have a problem, where I want to activate the flow at the specified time but do not use flow inject, how do I do it? Thanks Before
I'm not sure I understand what you want to do.
A flow is only triggered when something happens.
If nothing happens, the flow won't do anything.
If you open the inject node you will see this.
Click on that v drop down thingy and it will open up a list of options.
You can then set a time when you want the node to inject its signal.
Like so:
Does that help?
