how can i send file csv from raspberry to my laptop with internet
raspberry and laptop use deferent router
the easiest way is using the program winSCP
Did you give up on email then?
A possible alternative approach is to send the file contents over MQTT.
Could you explain whether you are trying to do this manually or need to create an automated process?
i need to send file data in form csv every 6hours to cloud or to pc via any protocol like sftp
There are so many possible ways. I think you need to show us what you have tried and any problems you have encountered.
Other options:
Another option is email.
have a look at :sftp
Another option could be to use Telegram.
It has an API and is capable of sending/receiving many file-types including CSV (as a buffer object).
