I'm totally new to node red, and also raspberry, and I am trying to fight to move txt files to a pc within the network.
I trying use the "node-red-contrib-fs-ops" move node , there no problem when files are moved between folders within raspberry.
But an error occurs when the file tries to be moved to a folder with the root on another pc within the network.
this folder is properly shared, and I can access it by browsing the network.
Can someone point me the right way?
matrixratrix:
an error occurs
What error does it tell you?
I don't think you can simply copy files from a Pi to a Windows share without mounting the windows share on the Pi or other involved methods
I've never managed to do it
Thank you,
In fact is not windons, is Centos (linux), but it makes no difference anyway, it's exactly the same error
linux or windons,
There is any away to mount a unit by node-red?
If you are copying from one machine to another, then I'd use the scp command line tool to do the copy. Once I had the command working outside of Node-RED, I'd use an Exec node to run it from within Node-RED.
Sorry, "scp"? here I can set?
Colin
26 October 2019 16:16
8
I agree that SCP is likely to be the easiest between 2 Linux devices.
If you really do need to use the SMB share, look here:
https://wiki.samba.org/index.php/Mounting_samba_shares_from_a_unix_client
