Hi, ![]()
I have create new UI Dashboard widget node. But I have some problem about unit test.
In my new UI Dashboard widget node main function, there are require checked about node-red-dashboard. See below,
function UiWidgetThermometer(config) {
let node = this;
let done = null;
try {
if (ui === undefined) {
ui = RED.require("node-red-dashboard")(RED); <----------- THIS
RED.nodes.createNode(this, config);
Below code is my unit test, when I run it, there is an error occured (not pass). I had checked n1 object, result n1 equals 'null'.
const should = require("should");
const helper = require("node-red-node-test-helper");
const nodeUiWidgetThermometer = require("../nodes/ui_widget_thermometer.js");
helper.init(require.resolve('node-red'));
describe('UI Widget Temperature Node', function () {
beforeEach((done) => {
helper.startServer(done);
afterEach((done) => {
helper.unload();
helper.stopServer(done);
it('should be loaded', (done) => {
const flow = [
type: "ui_widget_thermometer",
helper.load(nodeUiWidgetThermometer, flow, () => {
const n1 = helper.getNode("n1"); <-------- CHECKED n1 = null
try {
n1.should.have.property("name", "test_node");
done();
} catch (err) {
done(err);
But If I remove below require node-red-dashboard section in my UI widget code. And then I run unit test again, the result is pass.
So, how can I unit test created UI Dashboard widget node? ![]()
