In the function node I have a line that looks like this:
msg.payload.Rad1W = msg.payload.data.devices_status.ec62608de1cc["switch:0"].apower
Now... I would like to use the variables from the sub flow to replace the places 'ec62608de1cc' & '["switch:0"].'
How do insert the variables into those places so It can look something like this:
msg.payload.Rad1W = msg.payload.data.devices_status.Variable1Variable2.apower
const id = env.get('id') // e.g. ec62608de1cc
const prop = env.get('prop') // e.g. switch:0
msg.payload.Rad1W = msg.payload.data.devices_status[id][prop].apower
return msg
NOTE: I would recommend you break this down and add null/undefined guards e.g
if (!id) {
node.error('id is not set')
return null
if (!prop) {
node.error('prop is not set')
return null
const stat = msg.payload?.data?.devices_status?.[id]
if (!stat) {
node.error('device status for id "' + id + '" was not found in the msg')
return null
const statProp = stat[prop]
if (!statProp) {
node.error('device status property "' + prop + '" for id "' + id + '" was not found in the msg')
return null
msg.payload.Rad1W = statProp.apower
return msg
↑ 100% untested - but should get you close ↑
Awesome, with some modifications it did exactly what I needed!
