How to pass the property name as a variable?
Hello Community,
i m trying to create a subflow where the "Environment variables" of the subflow is a property name.
so inside my subflow i could have a function that can then access the value in the property such as:
msg.payload.{some_variable_entered_from_the_sub_flow_variables_box}
is there a way to do that?
yes.
You can use square bracket notation
example...
var prop = "payload";
var value = msg[prop];
or the node-red helper function RED.util.getObjectProperty...
var value = RED.util.getObjectProperty(msg,prop);
The getObjectProperty helper function will also get nested properties e.g...
var prop = "payload.data.value";
As for getting the "Environment variables" - assume you know how to do that already?
thank you for the prompt reply Steve,
I assume getting the Environment Variables is done by using: ${enviroment_variable}
i tried that in a Function like this: but did not work :frowning:
var prop = ${enviroment_variable};
Hi @akd02
The docs for using environment variables in your flows are here: Using environment variables : Node-RED
Thanks guys! truly appreciate it
i got it now... below is my working example:
var prop = env.get("Property");
//var value = msg[prop]; // did not work :frowning:
var value = RED.util.getObjectProperty(msg,prop); //worked ok!!! :slight_smile:
msg.payload = value; // returns the value inside the Property that was set in the Subflow's template
