How I can create SAP notification with Babi function modules in sequence (Create ,save and commit)
Dears
I need to create maintenance notification from SAP by sapRFC
I use FM BAPI_ALM_NOTIF_CREATE and BAPI_ALM_NOTIF_SAVE and BAPI_TRANSACTION_COMMIT in series , notification created with temp. number %0000000001 and cannot save because function executed individually how I can run in sap in sequence to update notification in SAP DB
I used node-red-contrib-saprfc in Node-red version 4.0.2
Hi @alnashar2004 ,welcome to the forum.
I have moved your question to its own topic. The thread you posted on is over 5 years old and your question is not directly related.
For users to assist, please let us know your Node-RED version and which (if any) SAP contrib nodes you are using.
Please note, I read most threads on the forum and SAP is rarely (if ever) mentioned. YMMV
Thanks you
NP, however you should probably add the additional info :man_shrugging:
I started the last discussion. It was indeed 5 years ago and to be honest, I spent very little time with the saprfc node, so I cannot be much help. Sorry.
Thank you
