Node-RED Integration with SAP
Hello, I am an SAP Consultant (Integration),i wanted to extract data from Node-RED to SAP system through SAP PI/PO. I would like to know what are the connectivity options are available with Node RED(cloud) for data extraction to the SAP system?
it is possible to use SOAP/HTTP protocols or any other type of communication?
If in-case connectivity is possible, Node-RED can push data based on events and/or manual activity? or external system(SAP) should always pull data from Node-RED?
Look here (and that's on top of rest / http / FTP / etc)
Yes. And pretty much anything you can think of
Both. Whatever you can think of ( within reason )
Up to you. Push or pull.
