Hi all
I'm struggling with calculate length msg.payload. Is there any way to do it? In addition I want to put 0 in front of msg.payload in case of length of msg.payload is lower than 5 characters. Msg.payload is string.
Thanks for help ![]()
Hi all
Strings and arrays have a length property.
msg.payload.length will return the string length as an integer
You can also just pad the start of the string if less than x chars.
str.padstart()
msg.payload = msg.payload.padStart(5,"0")
var alt_var = msg.payload ;
let msglength = alt_var.length ;
If ( msglength < 5 ) {
msg.payload = "0" + alt_var ;
This would be a way to do it but best to read up in javascript functions?
Hi to all!
I have this debug as database output:
13/02/2023, 16:21:43[node: debug 22](http://127.0.0.1:1880/#)
SELECT name, lat, lon, type, status FROM stations : msg.payload : Object
object
lat: 43.1339
lon: 11.06825
type: 0
status: 0
13/02/2023, 16:23:57node: debug 22
SELECT name, status FROM stations WHERE name = $stazione : msg.payload : Object
object
status: 0
Using msglength = alt_var.length as new payload I always get name: undefined as output.
I need to understand how discriminate between two database output queries....
Thanks,
Your debug suggests that msg.payload is an object.
Try var size = Object.keys(msg.payload).length;
Object.keys() gives you an array ["name", "status"] An array has a length property.
