Can't use .length in my array data
in my array has two data. but node script can't length it
Data :
{"rootId":"0759da852d9fb76f79297e8cfc3d6ce7","requestId":"f396bc7dc58796e5:-644c5706:176e12ece07:-8000:3924","details":{"tlp":2,"caseTemplate":null,"description":"AIE: TLI - Command Shell Possible Success from 27.75.99.4 to 113.53.233.66 at 2021-01-24T03:32:04","tags":["Logthyrhm","Automate"],"lastSyncDate":1611600578646,"customFields":{"alertRule":{"order":0,"string":"AIE: TLI - Command Shell Possible Success"},"application":{"order":1,"string":""},"destinationPort":{"order":3,"string":"80"},"sourcePort":{"order":2,"string":"80"}},"status":"New","severity":2,"title":"AIE: TLI - Command Shell Possible Success from 27.75.99.4 to 113.53.233.66","follow":true},"operation":"Creation","objectId":"0759da852d9fb76f79297e8cfc3d6ce7","startDate":1611600578713,"objectType":"alert","base":true,"object":{"_routing":"0759da852d9fb76f79297e8cfc3d6ce7","date":1611600578000,"severity":2,"customFields":{"alertRule":{"order":0,"string":"AIE: TLI - Command Shell Possible Success"},"application":{"order":1,"string":""},"destinationPort":{"order":3,"string":"80"},"sourcePort":{"order":2,"string":"80"}},"caseTemplate":null,"_type":"alert","description":"AIE: TLI - Command Shell Possible Success from 27.75.99.4 to 113.53.233.66 at 2021-01-24T03:32:04","lastSyncDate":1611600578646,"source":"172.25.5.20","title":"AIE: TLI - Command Shell Possible Success from 27.75.99.4 to 113.53.233.66","type":"Attack","follow":true,"tags":["Logthyrhm","Automate"],"createdAt":1611600578646,"_parent":null,"createdBy":"apiuser","tlp":2,"_id":"0759da852d9fb76f79297e8cfc3d6ce7","id":"0759da852d9fb76f79297e8cfc3d6ce7","sourceRef":"aa51b4","_version":1,"artifacts":[{"tlp":2,"tags":[],"data":"27.75.99.4","ioc":false,"sighted":false,"message":null,"dataType":"ip"},{"tlp":2,"tags":[],"data":"113.53.233.66","ioc":false,"sighted":false,"message":null,"dataType":"ip"}],"status":"New"}}
My code
what's wrong ?
Not sure as can not see the objects origin in the image, but maybe it's msg.artifacts
it's all object
msg.payload.object.artifacts
Read this it will tell you how to find paths, using the debug panel.
https://nodered.org/docs/user-guide/messages#understanding-the-structure-of-a-message
it's still same
Then you are not showing the whole object, is object living inside msg.payload or in just msg ?
Feed the incoming message into a debug node set to show Complete Message and post a screenshot here. Then we will understand what you have.
Have you read and understood the document linked earlier?
