How to choose the highest temperature value in 8x8 array of amg8833 and display it on the dashboard?
Hi, i have a problem in writing the function to display only the highest value in the 8x8 array of AMG8833. below is my currently dashboard. but for the temperature reading value is not correct. I want to display on the temperature reading value the highest temperature that is display on the 8x8 array of thermal imaging.
here is my function for the temperature reading.
Please show us the data used to render the thermal image
Better still, use the "copy value" button on the debug to grab the actual values as text & share your flow.
the flow of my node
Unfortunately, I can not use pictures to re-create (or solve) your problem.
  • For a flow - Use the node-red export feature (CTRL+E)
  • for data in a debug message - use the "copy value" button on the debug message property
Try something like this
[{"id":"942c070f.f38758","type":"inject","z":"c791cbc0.84f648","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[[1,2,3,4],[5,6,7,8],[2,3,4,5],[3,4,5,6]]","payloadType":"json","x":200,"y":220,"wires":[["b6f5da19.9d47d8"]]},{"id":"b6f5da19.9d47d8","type":"change","z":"c791cbc0.84f648","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.*^($)[-1]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":220,"wires":[["8a8158b3.d3d318","aa51af73.3bbed"]]},{"id":"8a8158b3.d3d318","type":"ui_gauge","z":"c791cbc0.84f648","name":"","group":"b9d366f18ff7ae74","order":22,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"","x":650,"y":220,"wires":[]},{"id":"aa51af73.3bbed","type":"debug","z":"c791cbc0.84f648","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":600,"y":360,"wires":[]},{"id":"b9d366f18ff7ae74","type":"ui_group","name":"test","tab":"ffba43d73860d25d","order":1,"disp":true,"width":12,"collapse":false},{"id":"ffba43d73860d25d","type":"ui_tab","name":"Level","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
sorry.. here is my node flow
[{"id":"948243a3.6a4c2","type":"tab","label":"Thermal Image","disabled":false,"info":""},{"id":"c0f81119.2fa26","type":"mqtt in","z":"948243a3.6a4c2","name":"","topic":"/thermal/status","qos":"0","datatype":"auto","broker":"c11e7bc99adf471c","nl":false,"rap":false,"inputs":0,"x":120,"y":240,"wires":[["250280cb.2d764"]]},{"id":"6ca67c67.5158f4","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":570,"y":200,"wires":},{"id":"7f0330d.502b7d","type":"mqtt in","z":"948243a3.6a4c2","name":"","topic":"/thermal/thermal","qos":"0","datatype":"auto","broker":"c11e7bc99adf471c","nl":false,"rap":false,"inputs":0,"x":120,"y":400,"wires":[["5ff1fcf0.3046e4","cb9daecb.6bbc4","42f56a4e76409de7"]]},{"id":"5ff1fcf0.3046e4","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":400,"wires":},{"id":"250280cb.2d764","type":"json","z":"948243a3.6a4c2","name":"","property":"payload","action":"","pretty":false,"x":330,"y":240,"wires":[["6ca67c67.5158f4","eed49414.163348","bc13ee80.e8f6a"]]},{"id":"cb9daecb.6bbc4","type":"function","z":"948243a3.6a4c2","name":"Render image","func":"let camColors = ["#0a00bb","#0b00ba","#0c00ba","#0d00b9","#0e00b8","#0f00b7","#1000b7","#1100b6","#1200b5","#1300b4","#1400b4","#1500b3","#1600b2","#1700b1","#1800b1","#1800b0","#1900af","#1a00ae","#1b00ae","#1c00ad","#1d00ac","#1e00ac","#1f00ab","#2000aa","#2100a9","#2200a9","#2300a8","#2400a7","#2500a6","#2600a6","#2700a5","#2800a4","#2900a3","#2a00a3","#2b00a2","#2c00a1","#2d00a0","#2e00a0","#2f009f","#30009e","#31009e","#32009d","#33009c","#33009b","#34009b","#35009a","#360099","#370098","#380098","#390097","#3a0096","#3b0095","#3c0095","#3d0094","#3e0093","#3f0093","#400092","#410091","#420090","#430090","#44008f","#45008e","#46008d","#47008d","#48008c","#49008b","#4a008a","#4b008a","#4c0089","#4d0088","#4e0087","#4e0087","#4f0086","#500085","#510085","#520084","#530083","#540082","#550082","#560081","#570080","#58007f","#59007f","#5a007e","#5b007d","#5c007c","#5d007c","#5e007b","#5f007a","#600079","#610079","#620078","#630077","#640077","#650076","#660075","#670074","#680074","#690073","#690072","#6a0071","#6b0071","#6c0070","#6d006f","#6e006e","#6f006e","#70006d","#71006c","#72006b","#73006b","#74006a","#750069","#760069","#770068","#780067","#790066","#7a0066","#7b0065","#7c0064","#7d0063","#7e0063","#7f0062","#800061","#810060","#820060","#83005f","#84005e","#85005e","#85005d","#86005c","#87005b","#88005b","#89005a","#8a0059","#8b0058","#8c0058","#8d0057","#8e0056","#8f0055","#900055","#910054","#920053","#930052","#940052","#950051","#960050","#970050","#98004f","#99004e","#9a004d","#9b004d","#9c004c","#9d004b","#9e004a","#9f004a","#a00049","#a00048","#a10047","#a20047","#a30046","#a40045","#a50044","#a60044","#a70043","#a80042","#a90042","#aa0041","#ab0040","#ac003f","#ad003f","#ae003e","#af003d","#b0003c","#b1003c","#b2003b","#b3003a","#b40039","#b50039","#b60038","#b70037","#b80036","#b90036","#ba0035","#bb0034","#bb0034","#bc0033","#bd0032","#be0031","#bf0031","#c00030","#c1002f","#c2002e","#c3002e","#c4002d","#c5002c","#c6002b","#c7002b","#c8002a","#c90029","#ca0028","#cb0028","#cc0027","#cd0026","#ce0026","#cf0025","#d00024","#d10023","#d20023","#d30022","#d40021","#d50020","#d60020","#d6001f","#d7001e","#d8001d","#d9001d","#da001c","#db001b","#dc001b","#dd001a","#de0019","#df0018","#e00018","#e10017","#e20016","#e30015","#e40015","#e50014","#e60013","#e70012","#e80012","#e90011","#ea0010","#eb000f","#ec000f","#ed000e","#ee000d","#ef000d","#f0000c","#f1000b","#f1000a","#f2000a","#f30009","#f40008","#f50007","#f60007","#f70006","#f80005","#f90004","#fa0004","#fb0003","#fc0002","#fd0001","#fe0001","#ff0000"];\nlet MINTEMP = 20.0;\nlet MAXTEMP = 32.0;\n\n\nlet html = "<table border=\"0\" padding=\"0\" spacing=\"0\">";\n\nlet image = msg.payload.split(",");\n\n// auto calculate min and max\nMINTEMP = 200.0;\nMAXTEMP = 0.0;\nfor (let k=0;k<64;k++) {\n let value = parseFloat(image[k]);\n if (value<MINTEMP) { MINTEMP = value; }\n if (value>MAXTEMP) { MAXTEMP = value; }\n}\nif (MAXTEMP-MINTEMP<10) { MAXTEMP = MINTEMP + 10.0; }\n\nfor (let i=0;i<8;i++) {\n html = html + ""\n for (let j=0;j<8;j++) {\n let mycolor = parseFloat(image[i*8+j]);\n let temp =parseFloat(image[(i8+j)])+5.0;\n if (mycolor<MINTEMP) { mycolor = MINTEMP; }\n if (mycolor>MAXTEMP) { mycolor = MAXTEMP; }\n mycolor = Math.floor(255(mycolor-MINTEMP)/(MAXTEMP-MINTEMP));\n //html = html + mycolor + ",";\n if (mycolor>253) { mycolor = 253; }\n mycolor = camColors[mycolor];\n html = html + "<td bgcolor=\""+mycolor+"\" width=\"40px\" height=\"40px\" align=\"center\" valign=\"middle\"><font size=\"2\" color= \"#CCCCCC\">"+temp+""\n }\n html = html + ""\n}\n\nhtml = html + ""\n\nmsg.payload = html;\n\nreturn [msg,{"payload":MINTEMP},{"payload":MAXTEMP}];","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":,"x":400,"y":440,"wires":[["a3c4087e.bc2c28","ce18a3aa.bdd22"],,]},{"id":"a3c4087e.bc2c28","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":460,"wires":},{"id":"ce18a3aa.bdd22","type":"ui_template","z":"948243a3.6a4c2","group":"38a41d52.5ca782","name":"","order":1,"width":"8","height":"10","format":"<div ng-bind-html="msg.payload">","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":640,"y":520,"wires":[]},{"id":"eed49414.163348","type":"ui_text","z":"948243a3.6a4c2","group":"edc77171.40e6d","order":0,"width":0,"height":0,"name":"","label":"RSSI","format":"{{msg.payload.rssi}}","layout":"row-spread","x":550,"y":240,"wires":},{"id":"bc13ee80.e8f6a","type":"ui_text","z":"948243a3.6a4c2","group":"edc77171.40e6d","order":0,"width":0,"height":0,"name":"","label":"Uptime [min]","format":"{{msg.payload.uptime}}","layout":"row-spread","x":570,"y":300,"wires":},{"id":"42f56a4e76409de7","type":"function","z":"948243a3.6a4c2","name":"","func":"\nlet image = msg.payload.split(",");\n// auto calculate min and max\n//MINTEMP = 200.0;\n//MAXTEMP = 32.0;\nfor (let k=0;k<=64;k++) {\n value = parseFloat(image[k-1])+5.0;\n \n}\nreturn [msg,{"payload":value}];\n\n\n","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":,"x":380,"y":740,"wires":[,["6010fca4ae55b1d5"],]},{"id":"091e8cc89e14a149","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":950,"y":640,"wires":},{"id":"fe10b2ec158fb17a","type":"ui_text","z":"948243a3.6a4c2","group":"2e00d8e7.308948","order":2,"width":0,"height":0,"name":"","label":"Temperature Reading","format":"{{msg.payload}}","layout":"row-spread","x":980,"y":700,"wires":},{"id":"5a149f8f41ade161","type":"switch","z":"948243a3.6a4c2","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"37.5","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":880,"wires":[["0accfdcc99a7ae03","3c4250b8336f3ac7","aeefcd424d5ecb79"]]},{"id":"0accfdcc99a7ae03","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":860,"wires":},{"id":"3c4250b8336f3ac7","type":"change","z":"948243a3.6a4c2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":900,"wires":[["4d9754416fede2fd"]]},{"id":"4d9754416fede2fd","type":"ui_switch","z":"948243a3.6a4c2","name":"","label":"Temperature > 37.5 ","tooltip":"","group":"2e00d8e7.308948","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1090,"y":900,"wires":[["dfc0ec304cfacc60"]]},{"id":"6010fca4ae55b1d5","type":"delay","z":"948243a3.6a4c2","name":"","pauseType":"rate","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":660,"y":740,"wires":[["fe10b2ec158fb17a","a4d83157f77a1c59","091e8cc89e14a149","5e62cf89bf096559","5a149f8f41ade161"]]},{"id":"a4d83157f77a1c59","type":"ui_gauge","z":"948243a3.6a4c2","name":"","group":"2e00d8e7.308948","order":3,"width":0,"height":0,"gtype":"gage","title":"TEMPERATURE","label":"celcius","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6c700","#ca3838"],"seg1":"","seg2":"","x":970,"y":760,"wires":},{"id":"13bbebf8df4d16e8","type":"mysql","z":"948243a3.6a4c2","mydb":"333d95a779e4070c","name":"thermal image","x":1340,"y":840,"wires":[]},{"id":"51ec4eb7cc866ee3","type":"inject","z":"948243a3.6a4c2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":940,"y":420,"wires":[]},{"id":"5e62cf89bf096559","type":"function","z":"948243a3.6a4c2","name":"mysql temperature","func":"const temp = msg.payload;\nmsg.payload = [temp];\nmsg.topic = "INSERT INTO temperature(temperature) VALUES (?)";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":950,"y":820,"wires":[["8dac0e4c11314159","13bbebf8df4d16e8"]]},{"id":"8dac0e4c11314159","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1210,"y":760,"wires":},{"id":"13ca8bb0941dc8bb","type":"ui_form","z":"948243a3.6a4c2","name":"","label":"","group":"2e00d8e7.308948","order":3,"width":0,"height":0,"options":[{"label":"ID","value":"id","type":"number","required":true,"rows":null},{"label":"Temperature","value":"temp","type":"number","required":true,"rows":null}],"formValue":{"id":"","temp":""},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":90,"y":980,"wires":[["1b88ea0c9ba9f547","11f13721cf323d35"]]},{"id":"1b88ea0c9ba9f547","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":390,"y":1100,"wires":},{"id":"11f13721cf323d35","type":"function","z":"948243a3.6a4c2","name":"mysql form","func":"const data = msg.payload;\nmsg.payload = [data.id,data.temp];\nmsg.topic = "INSERT INTO Recorded_temperature(MATRIC_NO, TEMPERATURE) VALUES (?,?)";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":,"x":410,"y":1000,"wires":[["a6281b5770ae6090","ca32eedc818e66f5","a3dd54e62a110bd0"]]},{"id":"dfc0ec304cfacc60","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1290,"y":920,"wires":},{"id":"a6281b5770ae6090","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":1020,"wires":},{"id":"ca32eedc818e66f5","type":"mysql","z":"948243a3.6a4c2","mydb":"333d95a779e4070c","name":"","x":740,"y":1060,"wires":[]},{"id":"a3dd54e62a110bd0","type":"switch","z":"948243a3.6a4c2","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"3.75","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":630,"y":1140,"wires":[["8d3855ddde415822"]]},{"id":"8d3855ddde415822","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":1140,"wires":},{"id":"e119968e857acfb9","type":"remote-access","z":"948243a3.6a4c2","confignode":"42bfc4b2390226eb","name":"","verbose":0,"x":120,"y":820,"wires":[]},{"id":"f1f0da6adfe34e02","type":"remote-notification","z":"948243a3.6a4c2","confignode":"42bfc4b2390226eb","name":"","notificationTitle":"payload.title","notificationTitleType":"msg","notificationBody":"payload.body","notificationBodyType":"msg","notificationSound":"bikebell","notificationSoundComputed":"payload.sound","notificationSoundComputedType":"msg","output":1,"x":1110,"y":960,"wires":[]},{"id":"aeefcd424d5ecb79","type":"change","z":"948243a3.6a4c2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{"title":"Temperature warning","body":"The temperature is greater than 37.5!"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":960,"wires":[["f1f0da6adfe34e02"]]},{"id":"c11e7bc99adf471c","type":"mqtt-broker","name":"","broker":"broker.hivemq.com","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"38a41d52.5ca782","type":"ui_group","name":"THERMAL IMAGE DISPLAY","tab":"dd1d391f.548498","order":1,"disp":true,"width":"8","collapse":false},{"id":"edc77171.40e6d","type":"ui_group","name":"Device Status","tab":"dd1d391f.548498","order":3,"disp":true,"width":"6","collapse":false},{"id":"2e00d8e7.308948","type":"ui_group","name":"TEMPERATURE MEASUREMENT","tab":"dd1d391f.548498","order":2,"disp":true,"width":"6","collapse":false},{"id":"333d95a779e4070c","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"dataset","tz":"","charset":"UTF8"},{"id":"42bfc4b2390226eb","type":"remote-config","name":"Node-RED UI","host":"localhost","protocol":"http","port":"1880","baseurl":"/ui","instancehash":"2lsl07kxokhomreyytes7vjv7d6g6a9xtxxfxe3gpmfx7396ra0xwyvibnnzizgc","server":"nodered02.remote-red.com","region":"de"},{"id":"dd1d391f.548498","type":"ui_tab","name":"Thermal Imaging","icon":"image","order":1,"disabled":false,"hidden":false}]
sorry im still new to this...
where should i put this?
where ever you wish. You feed the array into the change node, the change node outputs the highest value.
Ps your flow json is corrupt , you need to paste the code between backtickd
eg
paste code here
Please☝️read this - your posted flow is not valid/importable
In order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
[{"id":"948243a3.6a4c2","type":"tab","label":"Thermal Image","disabled":false,"info":""},{"id":"c0f81119.2fa26","type":"mqtt in","z":"948243a3.6a4c2","name":"","topic":"/thermal/status","qos":"0","datatype":"auto","broker":"c11e7bc99adf471c","nl":false,"rap":false,"inputs":0,"x":120,"y":240,"wires":[["250280cb.2d764"]]},{"id":"6ca67c67.5158f4","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":570,"y":200,"wires":[]},{"id":"7f0330d.502b7d","type":"mqtt in","z":"948243a3.6a4c2","name":"","topic":"/thermal/thermal","qos":"0","datatype":"auto","broker":"c11e7bc99adf471c","nl":false,"rap":false,"inputs":0,"x":120,"y":400,"wires":[["5ff1fcf0.3046e4","cb9daecb.6bbc4","42f56a4e76409de7"]]},{"id":"5ff1fcf0.3046e4","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":400,"wires":[]},{"id":"250280cb.2d764","type":"json","z":"948243a3.6a4c2","name":"","property":"payload","action":"","pretty":false,"x":330,"y":240,"wires":[["6ca67c67.5158f4","eed49414.163348","bc13ee80.e8f6a"]]},{"id":"cb9daecb.6bbc4","type":"function","z":"948243a3.6a4c2","name":"Render image","func":"let camColors = [\"#0a00bb\",\"#0b00ba\",\"#0c00ba\",\"#0d00b9\",\"#0e00b8\",\"#0f00b7\",\"#1000b7\",\"#1100b6\",\"#1200b5\",\"#1300b4\",\"#1400b4\",\"#1500b3\",\"#1600b2\",\"#1700b1\",\"#1800b1\",\"#1800b0\",\"#1900af\",\"#1a00ae\",\"#1b00ae\",\"#1c00ad\",\"#1d00ac\",\"#1e00ac\",\"#1f00ab\",\"#2000aa\",\"#2100a9\",\"#2200a9\",\"#2300a8\",\"#2400a7\",\"#2500a6\",\"#2600a6\",\"#2700a5\",\"#2800a4\",\"#2900a3\",\"#2a00a3\",\"#2b00a2\",\"#2c00a1\",\"#2d00a0\",\"#2e00a0\",\"#2f009f\",\"#30009e\",\"#31009e\",\"#32009d\",\"#33009c\",\"#33009b\",\"#34009b\",\"#35009a\",\"#360099\",\"#370098\",\"#380098\",\"#390097\",\"#3a0096\",\"#3b0095\",\"#3c0095\",\"#3d0094\",\"#3e0093\",\"#3f0093\",\"#400092\",\"#410091\",\"#420090\",\"#430090\",\"#44008f\",\"#45008e\",\"#46008d\",\"#47008d\",\"#48008c\",\"#49008b\",\"#4a008a\",\"#4b008a\",\"#4c0089\",\"#4d0088\",\"#4e0087\",\"#4e0087\",\"#4f0086\",\"#500085\",\"#510085\",\"#520084\",\"#530083\",\"#540082\",\"#550082\",\"#560081\",\"#570080\",\"#58007f\",\"#59007f\",\"#5a007e\",\"#5b007d\",\"#5c007c\",\"#5d007c\",\"#5e007b\",\"#5f007a\",\"#600079\",\"#610079\",\"#620078\",\"#630077\",\"#640077\",\"#650076\",\"#660075\",\"#670074\",\"#680074\",\"#690073\",\"#690072\",\"#6a0071\",\"#6b0071\",\"#6c0070\",\"#6d006f\",\"#6e006e\",\"#6f006e\",\"#70006d\",\"#71006c\",\"#72006b\",\"#73006b\",\"#74006a\",\"#750069\",\"#760069\",\"#770068\",\"#780067\",\"#790066\",\"#7a0066\",\"#7b0065\",\"#7c0064\",\"#7d0063\",\"#7e0063\",\"#7f0062\",\"#800061\",\"#810060\",\"#820060\",\"#83005f\",\"#84005e\",\"#85005e\",\"#85005d\",\"#86005c\",\"#87005b\",\"#88005b\",\"#89005a\",\"#8a0059\",\"#8b0058\",\"#8c0058\",\"#8d0057\",\"#8e0056\",\"#8f0055\",\"#900055\",\"#910054\",\"#920053\",\"#930052\",\"#940052\",\"#950051\",\"#960050\",\"#970050\",\"#98004f\",\"#99004e\",\"#9a004d\",\"#9b004d\",\"#9c004c\",\"#9d004b\",\"#9e004a\",\"#9f004a\",\"#a00049\",\"#a00048\",\"#a10047\",\"#a20047\",\"#a30046\",\"#a40045\",\"#a50044\",\"#a60044\",\"#a70043\",\"#a80042\",\"#a90042\",\"#aa0041\",\"#ab0040\",\"#ac003f\",\"#ad003f\",\"#ae003e\",\"#af003d\",\"#b0003c\",\"#b1003c\",\"#b2003b\",\"#b3003a\",\"#b40039\",\"#b50039\",\"#b60038\",\"#b70037\",\"#b80036\",\"#b90036\",\"#ba0035\",\"#bb0034\",\"#bb0034\",\"#bc0033\",\"#bd0032\",\"#be0031\",\"#bf0031\",\"#c00030\",\"#c1002f\",\"#c2002e\",\"#c3002e\",\"#c4002d\",\"#c5002c\",\"#c6002b\",\"#c7002b\",\"#c8002a\",\"#c90029\",\"#ca0028\",\"#cb0028\",\"#cc0027\",\"#cd0026\",\"#ce0026\",\"#cf0025\",\"#d00024\",\"#d10023\",\"#d20023\",\"#d30022\",\"#d40021\",\"#d50020\",\"#d60020\",\"#d6001f\",\"#d7001e\",\"#d8001d\",\"#d9001d\",\"#da001c\",\"#db001b\",\"#dc001b\",\"#dd001a\",\"#de0019\",\"#df0018\",\"#e00018\",\"#e10017\",\"#e20016\",\"#e30015\",\"#e40015\",\"#e50014\",\"#e60013\",\"#e70012\",\"#e80012\",\"#e90011\",\"#ea0010\",\"#eb000f\",\"#ec000f\",\"#ed000e\",\"#ee000d\",\"#ef000d\",\"#f0000c\",\"#f1000b\",\"#f1000a\",\"#f2000a\",\"#f30009\",\"#f40008\",\"#f50007\",\"#f60007\",\"#f70006\",\"#f80005\",\"#f90004\",\"#fa0004\",\"#fb0003\",\"#fc0002\",\"#fd0001\",\"#fe0001\",\"#ff0000\"];\nlet MINTEMP = 20.0;\nlet MAXTEMP = 32.0;\n\n\nlet html = \"<table border=\\\"0\\\" padding=\\\"0\\\" spacing=\\\"0\\\">\";\n\nlet image = msg.payload.split(\",\");\n\n// auto calculate min and max\nMINTEMP = 200.0;\nMAXTEMP = 0.0;\nfor (let k=0;k<64;k++) {\n    let value = parseFloat(image[k]);\n    if (value<MINTEMP) { MINTEMP = value; }\n    if (value>MAXTEMP) { MAXTEMP = value; }\n}\nif (MAXTEMP-MINTEMP<10) { MAXTEMP = MINTEMP + 10.0; }\n\nfor (let i=0;i<8;i++) {\n    html = html + \"<tr>\"\n    for (let j=0;j<8;j++) {\n        let mycolor = parseFloat(image[i*8+j]);\n        let temp =parseFloat(image[(i*8+j)])+5.0;\n        if (mycolor<MINTEMP) { mycolor = MINTEMP; }\n        if (mycolor>MAXTEMP) { mycolor = MAXTEMP; }\n        mycolor = Math.floor(255*(mycolor-MINTEMP)/(MAXTEMP-MINTEMP));\n        //html = html + mycolor + \",\";\n        if (mycolor>253) { mycolor = 253; }\n        mycolor = camColors[mycolor];\n        html = html + \"<td bgcolor=\\\"\"+mycolor+\"\\\" width=\\\"40px\\\" height=\\\"40px\\\" align=\\\"center\\\" valign=\\\"middle\\\"><font size=\\\"2\\\" color= \\\"#CCCCCC\\\">\"+temp+\"</font></td>\"\n    }\n    html = html + \"</tr>\"\n}\n\nhtml = html + \"</table>\"\n\nmsg.payload = html;\n\nreturn [msg,{\"payload\":MINTEMP},{\"payload\":MAXTEMP}];","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":440,"wires":[["a3c4087e.bc2c28","ce18a3aa.bdd22"],[],[]]},{"id":"a3c4087e.bc2c28","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":460,"wires":[]},{"id":"ce18a3aa.bdd22","type":"ui_template","z":"948243a3.6a4c2","group":"38a41d52.5ca782","name":"","order":1,"width":"8","height":"10","format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":640,"y":520,"wires":[[]]},{"id":"eed49414.163348","type":"ui_text","z":"948243a3.6a4c2","group":"edc77171.40e6d","order":0,"width":0,"height":0,"name":"","label":"RSSI","format":"{{msg.payload.rssi}}","layout":"row-spread","x":550,"y":240,"wires":[]},{"id":"bc13ee80.e8f6a","type":"ui_text","z":"948243a3.6a4c2","group":"edc77171.40e6d","order":0,"width":0,"height":0,"name":"","label":"Uptime [min]","format":"{{msg.payload.uptime}}","layout":"row-spread","x":570,"y":300,"wires":[]},{"id":"42f56a4e76409de7","type":"function","z":"948243a3.6a4c2","name":"","func":"\nlet image = msg.payload.split(\",\");\n// auto calculate min and max\n//MINTEMP = 200.0;\n//MAXTEMP = 32.0;\nfor (let k=0;k<=64;k++) {\n    value = parseFloat(image[k-1])+5.0;\n   \n}\nreturn [msg,{\"payload\":value}];\n\n\n","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":740,"wires":[[],["6010fca4ae55b1d5"],[]]},{"id":"091e8cc89e14a149","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":950,"y":640,"wires":[]},{"id":"fe10b2ec158fb17a","type":"ui_text","z":"948243a3.6a4c2","group":"2e00d8e7.308948","order":2,"width":0,"height":0,"name":"","label":"Temperature Reading","format":"{{msg.payload}}","layout":"row-spread","x":980,"y":700,"wires":[]},{"id":"5a149f8f41ade161","type":"switch","z":"948243a3.6a4c2","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"37.5","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":880,"wires":[["0accfdcc99a7ae03","3c4250b8336f3ac7","aeefcd424d5ecb79"]]},{"id":"0accfdcc99a7ae03","type":"debug","z":"948243a3.6a4c2","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":860,"wires":[]},{"id":"3c4250b8336f3ac7","type":"change","z":"948243a3.6a4c2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":900,"wires":[["4d9754416fede2fd"]]},{"id":"4d9754416fede2fd","type":"ui_switch","z":"948243a3.6a4c2","name":"","label":"Temperature > 37.5 ","tooltip":"","group":"2e00d8e7.308948","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1090,"y":900,"wires":[["dfc0ec304cfacc60"]]},{"id":"6010fca4ae55b1d5","type":"delay","z":"948243a3.6a4c2","name":"","pauseType":"rate","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":660,"y":740,"wires":[["fe10b2ec158fb17a","a4d83157f77a1c59","091e8cc89e14a149","5e62cf89bf096559","5a149f8f41ade161"]]},{"id":"a4d83157f77a1c59","type":"ui_gauge","z":"948243a3.6a4c2","name":"","group":"2e00d8e7.308948","order":3,"width":0,"height":0,"gtype":"gage","title":"TEMPERATURE","label":"celcius","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6c700","#ca3838"],"seg1":"","seg2":"","x":970,"y":760,"wires":[]},{"id":"13bbebf8df4d16e8","type":"mysql","z":"948243a3.6a4c2","mydb":"333d95a779e4070c","name":"thermal image","x":1340,"y":840,"wires":[[]]},{"id":"51ec4eb7cc866ee3","type":"inject","z":"948243a3.6a4c2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":940,"y":420,"wires":[[]]},{"id":"5e62cf89bf096559","type":"function","z":"948243a3.6a4c2","name":"mysql temperature","func":"const temp = msg.payload;\nmsg.payload = [temp];\nmsg.topic = \"INSERT INTO temperature(temperature) VALUES (?)\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":820,"wires":[["8dac0e4c11314159","13bbebf8df4d16e8"]]},{"id":"8dac0e4c11314159","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1210,"y":760,"wires":[]},{"id":"13ca8bb0941dc8bb","type":"ui_form","z":"948243a3.6a4c2","name":"","label":"","group":"2e00d8e7.308948","order":3,"width":0,"height":0,"options":[{"label":"ID","value":"id","type":"number","required":true,"rows":null},{"label":"Temperature","value":"temp","type":"number","required":true,"rows":null}],"formValue":{"id":"","temp":""},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":90,"y":980,"wires":[["1b88ea0c9ba9f547","11f13721cf323d35"]]},{"id":"1b88ea0c9ba9f547","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":390,"y":1100,"wires":[]},{"id":"11f13721cf323d35","type":"function","z":"948243a3.6a4c2","name":"mysql form","func":"const data = msg.payload;\nmsg.payload = [data.id,data.temp];\nmsg.topic = \"INSERT INTO Recorded_temperature(MATRIC_NO, TEMPERATURE) VALUES (?,?)\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":1000,"wires":[["a6281b5770ae6090","ca32eedc818e66f5","a3dd54e62a110bd0"]]},{"id":"dfc0ec304cfacc60","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1290,"y":920,"wires":[]},{"id":"a6281b5770ae6090","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":1020,"wires":[]},{"id":"ca32eedc818e66f5","type":"mysql","z":"948243a3.6a4c2","mydb":"333d95a779e4070c","name":"","x":740,"y":1060,"wires":[[]]},{"id":"a3dd54e62a110bd0","type":"switch","z":"948243a3.6a4c2","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"3.75","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":630,"y":1140,"wires":[["8d3855ddde415822"]]},{"id":"8d3855ddde415822","type":"debug","z":"948243a3.6a4c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":1140,"wires":[]},{"id":"e119968e857acfb9","type":"remote-access","z":"948243a3.6a4c2","confignode":"42bfc4b2390226eb","name":"","verbose":0,"x":120,"y":820,"wires":[[]]},{"id":"f1f0da6adfe34e02","type":"remote-notification","z":"948243a3.6a4c2","confignode":"42bfc4b2390226eb","name":"","notificationTitle":"payload.title","notificationTitleType":"msg","notificationBody":"payload.body","notificationBodyType":"msg","notificationSound":"bikebell","notificationSoundComputed":"payload.sound","notificationSoundComputedType":"msg","output":1,"x":1110,"y":960,"wires":[[]]},{"id":"aeefcd424d5ecb79","type":"change","z":"948243a3.6a4c2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"title\":\"Temperature warning\",\"body\":\"The temperature is greater than 37.5!\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":960,"wires":[["f1f0da6adfe34e02"]]},{"id":"c11e7bc99adf471c","type":"mqtt-broker","name":"","broker":"broker.hivemq.com","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"38a41d52.5ca782","type":"ui_group","name":"THERMAL IMAGE DISPLAY","tab":"dd1d391f.548498","order":1,"disp":true,"width":"8","collapse":false},{"id":"edc77171.40e6d","type":"ui_group","name":"Device Status","tab":"dd1d391f.548498","order":3,"disp":true,"width":"6","collapse":false},{"id":"2e00d8e7.308948","type":"ui_group","name":"TEMPERATURE MEASUREMENT","tab":"dd1d391f.548498","order":2,"disp":true,"width":"6","collapse":false},{"id":"333d95a779e4070c","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"dataset","tz":"","charset":"UTF8"},{"id":"42bfc4b2390226eb","type":"remote-config","name":"Node-RED UI","host":"localhost","protocol":"http","port":"1880","baseurl":"/ui","instancehash":"2lsl07kxokhomreyytes7vjv7d6g6a9xtxxfxe3gpmfx7396ra0xwyvibnnzizgc","server":"nodered02.remote-red.com","region":"de"},{"id":"dd1d391f.548498","type":"ui_tab","name":"Thermal Imaging","icon":"image","order":1,"disabled":false,"hidden":false}]
Hi, there was really no need to post your entire flow - a cut down demo would suffice. You also didn't provide sample data.
never mind.
Here is a demo I knocked up
[{"id":"b20b0bace1cb8757","type":"function","z":"23a4d2dd73b6359f","name":"min max","func":"\nconst image = msg.payload.split(\",\");\nconst data = image.map(e => parseFloat(e) + 5.0);\nconst min = Math.min(...data);\nconst max = Math.max(...data);\n\nmsg.payload = {\n    min: min,\n    max: max\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":320,"wires":[["b1c2ac35c45cb973"]]},{"id":"7926e8b8790cd901","type":"function","z":"23a4d2dd73b6359f","name":"min and max separate","func":"\nconst image = msg.payload.split(\",\");\nconst data = image.map(e => parseFloat(e) + 5.0);\nconst min = Math.min(...data);\nconst max = Math.max(...data);\n\nreturn [{ payload: min }, { payload: max }];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":680,"y":380,"wires":[["d2213c2210e09113"],["1b5e47b734bfecf6"]]},{"id":"26f4abce7d70d21c","type":"inject","z":"23a4d2dd73b6359f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"30,20,40,33,44,26,27","payloadType":"str","x":440,"y":320,"wires":[["b20b0bace1cb8757","7926e8b8790cd901"]]},{"id":"b1c2ac35c45cb973","type":"debug","z":"23a4d2dd73b6359f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":910,"y":320,"wires":[]},{"id":"d2213c2210e09113","type":"debug","z":"23a4d2dd73b6359f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":910,"y":380,"wires":[]},{"id":"1b5e47b734bfecf6","type":"debug","z":"23a4d2dd73b6359f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":910,"y":440,"wires":[]}]
NOTE: for anyone looking at the image and thinking 25 is not the min - the OP had a formula to add 5.0 to the value. I included this in the demo (remove that if not required)
This seems to be the function node that feeds your gauge:
//MINTEMP = 200.0;
//MAXTEMP = 32.0;
I think you are trying to loop through all the values in the array, but you don't do anything with the measurements, so the value passed to the gauge comes from the last array element.
But your other function "Render image" does record MINTEMP and MAXTEMP. Why can't you send MAXTEMP to your gauge?
Edit - Looking at the picture you posted, I would expect the gauge to show 40.75 (35.75 + 5.0) so either I'm misunderstanding the code or else that picture is from an earlier attempt at the code.
And I suspect that
would be better as
    value = parseFloat(image[k])+5.0;
thank you.. i got it already
