How to commit json file inside flows folder using noder-red-contrib-flow-manager
I have enabled projects in node-red and also installed node-red-contrib-flow-manager, the issue am facing is am not able to commit the flow files which present inside flows folder.
Even i have tried remote deploy options by configuring the local url at staging and uat url at production it throws failed to retrieve state .
Welcome to the forum Geet!
If you go to the Flow page for that node and then to the NPM page of the flow
you can then use the link to get to the homepage for the node:
and then look at the issues for the node:
you will see someone else opened an issue about this three weks ago.
I'd suggest you add your information to that issue and hopefully the node's author will fix the situation.
I have added my issues. Many Thanks
