I'm using an MS-104BZ device with two gangs, and I would like that when I say 'Alexa, turn off the office light,' gang 1 is turned off.
In other words, how to pass the payload '{"state_l1": "ON"}' to Zigbee2MQTT
Any ideas on how I can do this?
I do not use the zigbee2MQTT node so I can only suggest that you use an ordinary MQTT out node, and you would send;
msg.topic =
zigbee2mqtt/${deviceName}/set
msg.payload = {state_l1: 'ON'}
Have you checked both the Command and Options dropdowns for a state_l1 option?
Thank you for your feedback. I was able to resolve the situation by sending the payload as per the following example
if (msg.payload) {
msg.payload = {"state_l1": "ON"};
} else {
msg.payload = {"state_l1": "OFF"};
