LIDL Smart LED bulb HG06106C
Hi.
I have got a LIDL LED bulb HG06106C and have connected it to Zigbee2Mqtt.
It works and I can change the colors.
My question is... I have Node-RED and can use the "node-red-contrib-zigbee2mqtt" add-on to get the state of my bulb, but how can I change the state for the bulb, so if the time is 18:00 then turn on the bulb with the color 255.0.0?
I'm not using Node-RED to HomeAssistant... but just to make some automations to handle my Zigbee2mqtt devices.
As you say, you can already "change the colors" then use an inject (or cron-plus) node set to trigger at 18:00 and send the same colour message to the device.
You don't need the node-red-contrib-zigbee2mqtt node. I don't use it and I am happily controlling a bunch of Ikea Zigbee devices.
The Zigbee2mqtt docs tell you what MQTT topic to use to control things.
Hi Steve-Mcl i'm change the color inside Zigbee2Mqtt dashboard :slight_smile:
Hi TotallyInformation
Yes Lidl HG06106C
But how do I use the info:
  • zigbee2mqtt/Light_livingroom/set
  • {"state": "ON"}
  • {"color":{"r":255,"g":0,"b":0}}
the payload for mqtt would be something like below.
"payload":  {
    "state": "ON",
    "color": {"r": 255,"g": 0,"b": 0}
Hi E1cid
Can see that :slight_smile: Thx.
And will the msg.payload be msg.payload.zigbee2mqtt.Light_livingroom or?
msg.payload would be
    "state": "ON",
and msg.topic would be
Hmm
I have tried this code, from my link..
    "state": "ON",
    "brightness": 38,
    "color": {
        "x": 0.6363636363636364,
        "y": 0.3333333333333333
    "color_mode": "xy",
    "color_temp": 62
But it's not working..
It's hard to say as i have no idea if your topic is correct.
Try installing mqtt explorer and subscribe to topic #, and then manually switch on the light, then in mqtt explorer you will see the payloads and topics required .
I forgot a "mqtt out" node...
After adding that, it worked... THX. :slight_smile:
