Anyone have sample flow to text files to PDF file
There are examples built in to node-red-contrib-pdfmake
Examples
Examples are provided using the default node-red way, i.e. use
importin the editor menu and look for examples in thenode-red-contrib-pdfmakepackage#1 simple text PDF
This is the first example found on the pdfmake website.
#2 image & svg example PDF
This is a custom example showing how to read an image from file and integrate it into the PDF. It also shows a simple SVG to be included as well.
Try them & then try using a file node to load your text file & pass the text to it.
Hi Steve let you guidline flow?
What have you tried?
Did you import any of the examples?
Do you have the text file loading into node-red?
Post your current work & someone will assist.
[{"id":"cf65376e4d875d23","type":"tab","label":"Flow 11","disabled":false,"info":"","env":[]},{"id":"292df816cf5b98e7","type":"debug","z":"cf65376e4d875d23","name":"file","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":570,"y":520,"wires":[]},{"id":"cb7bfed7.2054a","type":"change","z":"cf65376e4d875d23","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"combined[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":420,"wires":[[]]},{"id":"87182c66.4a1d3","type":"debug","z":"cf65376e4d875d23","name":"Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":950,"y":500,"wires":[]},{"id":"00345b79e1950558","type":"file function","z":"cf65376e4d875d23","name":"","filename":"D:\\log\\log.txt","reloadfile":true,"outputs":1,"x":430,"y":560,"wires":[["8aa58ee2326b776a","292df816cf5b98e7"]]},{"id":"376e69c962da4eb9","type":"file","z":"cf65376e4d875d23","name":"","filename":"","appendNewline":false,"createDir":true,"overwriteFile":"false","encoding":"none","x":840,"y":580,"wires":[["87182c66.4a1d3"]]},{"id":"8aa58ee2326b776a","type":"pdfmake","z":"cf65376e4d875d23","name":"","outputType":"base64","inputProperty":"payload","options":"{}","outputProperty":"payload","x":640,"y":580,"wires":[["376e69c962da4eb9"]]},{"id":"b620c47079446f2f","type":"inject","z":"cf65376e4d875d23","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":250,"y":540,"wires":[["00345b79e1950558"]]}]
