PDF file cut out
Hello!
Is it possible to get something out of a PDF file with Node Red and then save it as a PDF again?
The PDF is A4 and should then have about 105x148mm.
Here is an example.
The red part should be
test.pdf (13.9 KB)
Have a look through these to see if any can help you. Library - Node-RED
Hello!
Thank you for your mail.
Unfortunately, there are still things for text recognition
Sorry, I don't understand that sentence.
that the flow is only for OCR.
What flow is only for OCR?
Here are only things for OCR
https://flows.nodered.org/search?term=pdf&type=node
Are you sure?
Another possibility is to work out how to do it using tools that can be installed on your computer and then invoke that from node-red using an Exec node.
