How to create function on rpi node red with two gpio - if gpio1 == 1 && gpio2 ==0 then gpio3=1
The joy was brief. With inject node everything is ok but in practice with hardware pins, things don't work out that way. The attached picture shows the messages on the right. look at functions in a flow. Help.Preformatted text
[{"id":"7bbf6c01.b26624","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"2db2a33b.dee8dc","type":"function","z":"7bbf6c01.b26624","name":"","func":"if (msg.payload.gpio1 == 1 && msg.payload.gpio2 == 1) {\nmsg.payload = 1;\nreturn msg;\n}\nelse{\n msg.payload = 0;\nreturn msg;\n}\n\n ","outputs":1,"noerr":0,"x":490,"y":120,"wires":[["e7762b1.e6959d8"]]},{"id":"e7762b1.e6959d8","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":690,"y":120,"wires":[]},{"id":"cf592dd9.6aa23","type":"inject","z":"7bbf6c01.b26624","name":"gpio1 on","topic":"gpio1","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":160,"wires":[["c1ee0201.be6d9"]]},{"id":"c1ee0201.be6d9","type":"join","z":"7bbf6c01.b26624","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":200,"wires":[["2257545a.9ea27c","2db2a33b.dee8dc"]]},{"id":"2257545a.9ea27c","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":200,"wires":[]},{"id":"7bddbf31.4d53b","type":"inject","z":"7bbf6c01.b26624","name":"gpio2 on","topic":"gpio2","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":240,"wires":[["c1ee0201.be6d9"]]},{"id":"b6bb8a6.b792678","type":"inject","z":"7bbf6c01.b26624","name":"gpio1 off","topic":"gpio1","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":200,"wires":[["c1ee0201.be6d9"]]},{"id":"50bd9c40.c68974","type":"inject","z":"7bbf6c01.b26624","name":"gpio2 off","topic":"gpio2","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":280,"wires":[["c1ee0201.be6d9"]]},{"id":"407a809e.71686","type":"rpi-gpio in","z":"7bbf6c01.b26624","name":"","pin":"37","intype":"up","debounce":"25","read":false,"x":160,"y":340,"wires":[["384d8adf.464636"]]},{"id":"5efa9c17.e96944","type":"rpi-gpio in","z":"7bbf6c01.b26624","name":"","pin":"35","intype":"up","debounce":"25","read":false,"x":160,"y":400,"wires":[["384d8adf.464636"]]},{"id":"db5c91e3.4380c","type":"function","z":"7bbf6c01.b26624","name":"","func":"if (msg.payload.pi/35 == 1 && msg.payload.pi/37 == 1) {\nmsg.payload = 1;\nreturn msg;\n}\nelse{\n msg.payload = 0;\nreturn msg;\n}\n\n ","outputs":1,"noerr":0,"x":490,"y":320,"wires":[["8c2e7942.8a9ef8"]]},{"id":"8c2e7942.8a9ef8","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":650,"y":320,"wires":[]},{"id":"384d8adf.464636","type":"join","z":"7bbf6c01.b26624","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":330,"y":380,"wires":[["11365f4b.9ab771","db5c91e3.4380c"]]},{"id":"11365f4b.9ab771","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":610,"y":380,"wires":[]}]
