I am trying to set up a repository to create a custom node.
Since I want to share this repo between machines (with different OS), including the flows and custom nodes, I want to configure node-red to run locally from the repository's node_modules instead of installing it globally.
I have declared node-red as a dependency:
"dependencies": {
"@types/node-red": "^1.3.0"
"devDependencies": {
"mocha": "^10.2.0",
"node-red": "^3.0.2",
"node-red-node-test-helper": "^0.3.0"
and I have a script to start node-red there.
"scripts": {
"node-red": "npx node-red --settings ./node-red-files/settings.js --userDir ./node-red-files/user-dir"
As per this answer, inside of /user-dir/ I have created a symlink to a nodes folder that contains my custom node js and html file.
/node-red-files
/user-dir
/nodes --> ../../nodes
/nodes
- custom-node.js
- custom-node.html
node red starts successfully but the custom node is not visible. I am missing something?
Thank you very much!
Edit: BTW I would also be open to achieve this using docker / docker-compose
For a vanilla, non-docker solution, I think you are on the right lines. Maybe have a look at the alternate installer repo on my GitHub for ideas though, that presents a way of quickly creating local installed instances of node-red with a userDir that is contained within the master node-red folder so everything is in 1 place.
If you wanted to share a locally developed node into an instance, it is better to make sure that the node's folder has a proper package.json file. Then you can "install" it with npm install /nodes/mynode` or wherever you've put it (in its own sub-folder). That lets npm and node.js manage things for you.
Thak you for your answer!
I have found out in the mid-time that what is failing silently on my end is the require that localFileSystem does
node_modules/@node-red/registry/lib/localfilesystem.js
const pkg = require(packagefile) // <-- this fails
result.package = pkg
if(result.package) {
result.allowed = true
result.isPackage = true
result.isNodeRedModule = typeof result.package['node-red'] === 'object'
if(result.isNodeRedModule) {
result.isNodeRedModule = true;
result.allowed = registryUtil.checkModuleAllowed(pkg.name,pkg.version,loadAllowList,loadDenyList)
it throws a MODULE_NOT_FOUND error which node-red ignores.
I already did an npm install ./nodes/my-node but looks like it did not fix anything. (the package was copied to the repo root node_modules)
Besides that, I think npm install is not the best way if I want to keep the source code and the deployed node in sync.
The first error was fixed, I needed to set a complete path to my ./nodes folder.
I set it on settings.js in this way:
nodesDir: path.join(__dirname, '..', 'nodes');
The next error happens here:
set.types.forEach(function(t) { // <---
if (nodeTypeToId.hasOwnProperty(t)) {
set.err = new Error("Type already registered");
set.err.code = "type_already_registered";
set.err.details = {
type: t,
moduleA: getNodeInfo(t).module,
moduleB: set.module
my set does not have any types (it is undefined) I have no idea how to set it up
I use it constantly. My dev PC runs Node-RED under PM2 and I use its watch function to watch for changes to any files/folders that need a Node-RED restart. So I can edit my custom nodes and each change saved triggers a restart of Node-RED.
The type is defined in the modules package.json file. Details are in the node-red docs.
I found out the problem!
I had to remove the package.json file contained in my ./nodes folder
Yes, this is a good idea, It being so long since I used a watch. I will try it
