How to decode JWT?
I have set up a webhook from Shipmondo and added a secret key (they won't let you create a WH without one):
Receiving the message in Node-RED, the payload is encrypted.
I now need to decrypt the payload. I have tried using node-red-contrib-auth with the following guide but the result is still encrypted.
Here is the flow:
{"_msgid":"9402f88c6802448e","payload":{"data":"eyJhbGciOiJIUzI1NiJ9.IntcImFjdGlvblwiOlwiY29ubmVjdGlvbl90ZXN0XCIsXCJkYXRhXCI6e319Ig.Z4uoPKAYB9Mze_amXlttnzDC3aip3SqOy4yex-pFemc"},"req":{"_readableState":{"objectMode":false,"highWaterMark":16384,"buffer":{"head":null,"tail":null,"length":0},"length":0,"pipes":[],"flowing":true,"ended":true,"endEmitted":true,"reading":false,"sync":false,"needReadable":false,"emittedReadable":false,"readableListening":false,"resumeScheduled":false,"errorEmitted":false,"emitClose":true,"autoDestroy":false,"destroyed":false,"errored":null,"closed":false,"closeEmitted":false,"defaultEncoding":"utf8","awaitDrainWriters":null,"multiAwaitDrain":false,"readingMore":false,"dataEmitted":true,"decoder":null,"encoding":null},"_events":{},"_eventsCount":1,"socket":"[internal]","httpVersionMajor":1,"httpVersionMinor":1,"httpVersion":"1.1","complete":true,"headers":{"connection":"close","host":"a1.confluent.as","x-forwarded-scheme":"https","x-forwarded-proto":"https","x-forwarded-for":"34.240.195.248","x-real-ip":"34.240.195.248","content-length":"138","smd-resource-type":"Shipments","smd-webhook-name":"test","smd-action":"create","smd-user":"Sileco AS","content-type":"application/json","accept-encoding":"gzip;q=1.0,deflate;q=0.6,identity;q=0.3","accept":"*/*","user-agent":"Ruby","x-newrelic-id":"UwYHVVBQGwcCUFBQBgg=","x-newrelic-transaction":"PxQOWF8HXANTVQBTA1IHVwEFFB8EBw8RVU4aWwEBUFYDBggAAFVQUlVTA0NKQQEFU1dQUgFVFTs="},"rawHeaders":["Connection","close","Host","a1.confluent.as","X-Forwarded-Scheme","https","X-Forwarded-Proto","https","X-Forwarded-For","34.240.195.248","X-Real-IP","34.240.195.248","Content-Length","138","Smd-Resource-Type","Shipments","Smd-Webhook-Name","test","Smd-Action","create","Smd-User","Sileco AS","Content-Type","application/json","Accept-Encoding","gzip;q=1.0,deflate;q=0.6,identity;q=0.3","Accept","*/*","User-Agent","Ruby","X-Newrelic-Id","UwYHVVBQGwcCUFBQBgg=","X-Newrelic-Transaction","PxQOWF8HXANTVQBTA1IHVwEFFB8EBw8RVU4aWwEBUFYDBggAAFVQUlVTA0NKQQEFU1dQUgFVFTs="],"trailers":{},"rawTrailers":[],"aborted":false,"upgrade":false,"url":"/whtest","method":"POST","statusCode":null,"statusMessage":null,"client":"[internal]","_consuming":true,"_dumped":false,"baseUrl":"","originalUrl":"/whtest","_parsedUrl":{"protocol":null,"slashes":null,"auth":null,"host":null,"port":null,"hostname":null,"hash":null,"search":null,"query":null,"pathname":"/whtest","path":"/whtest","href":"/whtest","_raw":"/whtest"},"params":{},"query":{},"res":"[internal]","body":{"data":"eyJhbGciOiJIUzI1NiJ9.IntcImFjdGlvblwiOlwiY29ubmVjdGlvbl90ZXN0XCIsXCJkYXRhXCI6e319Ig.Z4uoPKAYB9Mze_amXlttnzDC3aip3SqOy4yex-pFemc"},"_body":true,"_passport":{"instance":{"_key":"passport","_strategies":{"session":{"name":"session","_key":"passport"},"bearer":{"name":"bearer","_realm":"Users"},"oauth2-client-password":{"name":"oauth2-client-password"},"anon":{"name":"anon"},"tokens":{"name":"tokens"}},"_serializers":[],"_deserializers":[],"_infoTransformers":[],"_framework":{},"_sm":{"_key":"passport"},"strategies":{},"_userProperty":"user"}},"route":{"path":"/whtest","stack":[{"name":"cookieParser","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"httpMiddleware","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"corsHandler","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"metricsHandler","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"jsonParser","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"urlencodedParser","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"multipartParser","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"rawBodyParser","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"<anonymous>","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"},{"name":"<anonymous>","keys":[],"regexp":{"__enc__":true,"type":"regexp","data":"/^\\/?$/i"},"method":"post"}],"methods":{"post":true}},"cookies":{},"signedCookies":{}},"res":{},"token":{"access_token":"eyJhbGciOiJIUzI1NiJ9.IntcImFjdGlvblwiOlwiY29ubmVjdGlvbl90ZXN0XCIsXCJkYXRhXCI6e319Ig.Z4uoPKAYB9Mze_amXlttnzDC3aip3SqOy4yex-pFemc"},"error":{"message":"TypeError: jwtString.split is not a function","code":"general"}}
The key to decrypt the message is whtest1234.
Can anyone help me find a working method to decrypt the payload?
node-red-contrib-jwt seems to work to decode it
Test Flow
[{"id":"09d4dfb3b970c52f","type":"inject","z":"54efb553244c241f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":270,"y":2180,"wires":[["2afde891275a7636"]]},{"id":"2afde891275a7636","type":"function","z":"54efb553244c241f","name":"data","func":"msg = {\n    \"payload\":\n        \"eyJhbGciOiJIUzI1NiJ9.IntcImFjdGlvblwiOlwiY29ubmVjdGlvbl90ZXN0XCIsXCJkYXRhXCI6e319Ig.Z4uoPKAYB9Mze_amXlttnzDC3aip3SqOy4yex-pFemc\"\n\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":2180,"wires":[["1bdc1426d5758106"]]},{"id":"7ae7e01ee00a8594","type":"debug","z":"54efb553244c241f","name":"debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":780,"y":2180,"wires":[]},{"id":"1bdc1426d5758106","type":"jwt verify","z":"54efb553244c241f","name":"","alg":["HS256"],"jwkurl":"","secret":"whtest1234","key":"","signvar":"payload","storetoken":"payload","x":590,"y":2180,"wires":[["7ae7e01ee00a8594"]]}]
That works, thanks! But how do I convert it to a JSON Object instead of a string?
The example flow provided is just a test webhook. The real messages contain much more information, and therefore they are now cut off because it's a string.
This is what it should look like when decoded:
You can use the JSON node to convert the string to Javascript Object
In your example data, because it was wrapped in two double quotes, i had to use two nodes in a row .. weird.
It is already a JSON object (JSON objects are strings). I assume you mean that you want to convert from JSON to a javascript object.
This post should help to clarify the difference between Javascript objects and JSON.
The first JSON node sees a JSON string which starts and ends with quotes. The JSON spec says that "bla bla" is valid json and represents the string bla bla, so it converts it to that string (so it strips off the quotes. The second then takes the result, which is also valid JSON, and converts it to a javascript object.
