How to delete published flow from flow-library?
how to delete and update?
Hi @motebus
if you are logged in, then when you view a flow you created, you should see the following options in the sidebar:
Dashboard_Nest_thermostat__flow__-_Node-RED
Some how I broke a connection to the library flow and github when updating and then I couldn't access the original flow submission to remove it. Can you remove this flow? https://flows.nodered.org/flow/381151591811867c36d9acb145111577
If you search for IOT2050 you will now see two versions, one that works and this one above that gives: 404 - Thing not found.
Sorry, and thank you...
@MrRum - I have removed the duplicate
thank you
Hi, sorry, I have the same issue with:
https://flows.nodered.org/flow/808886a415e59d737229dd74a382a5b5
Mine is not duplicated, is just pointing to nowhere. If you can please remove I'll recreate a correct one.
Regards
F.
Hi @ffich, I'm on vacation this week. Don't have remote access to remove the flow. Remind me in a week if I haven't got to it.
Hi @knolleary, sure no problem. Enjoy your vacation :grin:
Regards
These are the only ones of yours I can find - which one should be removed ?
Hi, Jupiter example 2 is the one broken.
Regards
F.
Hi @dceejay, it happened again with Jupiter Example 01. This time I think i got the root cause. I had renamed the Readme.md file under my git account (from Readme.md to Jupiter Example 01.md), saved and synched. After a while I updated the description and tryed a new sync. After I tryed to sync the link was immediatly broken. I don't know if is a bug or the intended behaviour, but anyway I don't have necessairly the need of renaming the readme under git. If someone can please delete Jupiter Example 01 and Jupiter Example 02... now I know how to avoid the issue from happeing again.
BR
F.
Yes that would do it. You must have a readme or we won’t publish it
Ok @dceejay, that makes sense to me.
If you could please delete Jupiter example 01 and 02, I'll publish them again whitout touching the readme.
BR
F.
hmm -actually I can't from the default ui - will need to wait of @knolleary to get back from vacation. - or maybe you can rename them back to README.md in your gist.
I tryed... didn't work. I'll wait for @knolleary, no problem :grin:
F.
Hi @knolleary,
gentle reminder for the above issue. The broken links are:
https://flows.nodered.org/flow/d92fa7b040d5d6bc4b956dd909e895f4
Thanks and regards
F.
Thanks - both flows now removed.
Thanks Nick :slight_smile:
