I am sorry, I have published a misnamed node. How can I delete it?
https://flows.nodered.org/node/node-red-larkea-local-device
If you want to remove it from the npm repository, you can try to use the npm unpublish command.
You can then click the 'request refresh' button in the sidebar of the Flow Library page for your node and it should remove it. If not, let me know and I can remove it manually.
Thank you. It has been deleted!
