Hi
Is there a way for node red to detect if the mounted share folder is disconnected.
The folder is mounted to a linux based device CIFS-Install which has node red installed in it
When I use the read file node,it doesnt seem to give any error. Is there a way to monitor. The mounted share folder maybe empty but I still want to know if the folder is still connected.
Thank you
The way i usually do it - is to have the mount point have a file in there named UNMOUNTED
If the CIFS folder is not mounted then this file will exist on the local (NR) filesystem
Once i mount the CIFS folder into that location it will no longer see that UnMounted file
You can also extend if further by having a file called MOUNTED in the CIFS share - so when it is succesfully mounted this file will exist to NR
Craig
