How to display coordinates on worldmap to track the position of UAV
Hello all,
I have been working on a project where I have to display/track the coordinates of a UAV on worldmap, so far I was able to display the icon with the MQTT Topic but I am stuck now as I get an error when I want to loop through the coordinates and display them on the Worldmap and it does not seem to work? I am posting my code here:
var payload = msg.payload;
var topic = msg.topic;
//var lat = msg.lattitude;
//var lon = msg.longitude;
var name = msg.name;
msg.name = 'SIMULU';
var coordinates = {
    'x': [51.68,0],
    'y': [0,8.02]
if(topic == "gas/uas/0xWINKELBRUNN/gas_cmds/flight_state"){
    msg.navigation = "flight";
    msg.indicator_color = payload;
if(topic == "gas/uas/0xWINKELBRUNN/gas_cmds/guidance/geofence/dir"){
    msg.indicator_color = "red";
    msg.direction = parseFloat(payload).toFixed(2);
    for(var i=0;i<Object.keys(coordinates).length;i++){
        msg.payload = {
            'name': msg.name +i.toString(),
            'lat': coordinates[i].x,
            'lon': coordinates[i].y,
            'icon': 'fa-plane',
            'iconColor': 'blue',
            'layer': 'dir'
        node.send(msg);
if(topic != "gas/uas/0xWINJKELBRUNN/gas_cmds/guidance/geofence/dir"){
    msg.payload = {
        deleted : true,
        command : {
            clear : 'dir'
I get the following error: "TyperError: Cannot read property 'lat' of undefined". Any help or suggestion in this regard would be great. Thank you.
coordinates is an object, so should that not be
'lat': coordinates.x[i],
Hi @E1cid,
Thank you for the reply. I will try this too.
Just one question: Will my code above show the icon moving in the maps and track different values given by coordiantes object?
Hi @E1cid ,
The following is my flow in which I am trying to track the position of the UAV and also making a track line with it but it does not seems to draw/make a line in the maps ? I want to have multiple coordinates so that the UAV completes a flight path/track, can you see what I am doing wrong here?
Thank you.
        "id": "6a1a72128b6a3842",
        "type": "tab",
        "label": "User_Interface_SIMULU",
        "disabled": false,
        "info": "",
        "env": []
        "id": "ef044715988c5a66",
        "type": "function",
        "z": "6a1a72128b6a3842",
        "name": "Style Gauge",
        "func": "var msg1 = {}; \nvar msg2 = {}; \n\nvar circleColor = msg.indicator_color;        \nvar textColor = \"white\"; \n\n\nmsg1.ui_control = \n{   \"gtype\": \"compass\",\n    \"options\":{\n        \"gaugeColor\": circleColor, \n        \"levelColors\": [\"red\",\"blue\",\"yellow\"],\n        \"hideValue\": false,\n        \"textColor\": textColor,\n        \"gaugeHeight\": 1.50,\n        \"circleThickness\": 0.08,\n        \"height\": 20,\n    }\n};\n\nmsg2 = msg;\n\nreturn [msg1, msg2];",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 990,
        "y": 160,
                "bd4e5771559f76c8"
                "bd4e5771559f76c8"
        "id": "ba70f8b2eb787e10",
        "type": "mqtt in",
        "topic": "gas/uas/0xWINKELBRUNN/gas_cmds/flight_state",
        "qos": "0",
        "datatype": "auto-detect",
        "broker": "a635293a09a88a33",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 200,
        "y": 160,
                "18be8df23cba51a5",
                "f8cbfb25e1061605"
        "id": "3ac59ca0956a88d0",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 710,
        "y": 320,
        "id": "18be8df23cba51a5",
        "type": "function",
        "name": "Flight_State and Direction Functionality",
        "func": "var payload = msg.payload;\nvar topic = msg.topic;\nvar lat = msg.lattitude;\nvar lon = msg.longitude;\nvar name = msg.name;\nmsg.name = 'SIMULU';\n\nvar coordinates = {\n    'x': [51.68, 0],\n    'y': [0, 8.02]\n}\n\nif(topic == \"gas/uas/0xWINKELBRUNN/gas_cmds/flight_state\"){\n    msg.navigation = \"flight\";\n    msg.indicator_color = payload;\n    return msg;\n}\n\nif(topic == \"gas/uas/0xWINKELBRUNN/gas_cmds/guidance/geofence/dir\"){\n    msg.navigation = \"flight\";\n    msg.indicator_color = \"red\";\n    msg.direction = parseFloat(payload).toFixed(2);\n    for(var i=0;i<Object.keys(coordinates).length;i++){\n        msg.payload = {\n            'name': msg.name +i.toString(),\n            'lat': coordinates.x[i],\n            'lon': coordinates.y[i],\n            'icon': 'fa-plane',\n            'iconColor': 'blue',\n            'layer': 'dir'\n        }\n        node.send(msg);\n\n    }\n    return msg; \n    \n}\nif(topic != \"gas/uas/0xWINJKELBRUNN/gas_cmds/guidance/geofence/dir\"){\n    msg.payload = {\n        name : msg.name,\n        deleted : true,\n        command : {\n            clear : 'dir'\n        }\n    }\n}\n\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 620,
        "y": 220,
                "3ac59ca0956a88d0",
                "94f9e96c39bc49e1",
                "ef044715988c5a66",
                "fe77787841f182b0",
                "d91430ed79438eec",
                "4270807e778dbf05"
        "id": "3054da89f1625705",
        "type": "mqtt in",
        "topic": "gas/uas/0xWINKELBRUNN/gas_cmds/guidance/geofence/#",
        "qos": "0",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 220,
        "y": 280,
                "7e3d5f575013bbce"
        "id": "7e3d5f575013bbce",
        "type": "switch",
        "name": "Switch b/w topics",
        "property": "topic",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "gas/uas/0xWINKELBRUNN/gas_cmds/guidance/geofence/dir",
                "vt": "str"
                "t": "eq",
                "v": "gas/uas/0xWINKELBRUNN/gas_cmds/guidance/geofence/distance",
                "vt": "str"
                "t": "eq",
                "v": "gas/uas/0xWINKELBRUNN/gas_cmds/warning/geofence",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 3,
        "x": 350,
        "y": 400,
                "18be8df23cba51a5"
                "6b3fb520ddf64f94"
                "6b3fb520ddf64f94"
        "id": "6b3fb520ddf64f94",
        "type": "function",
        "name": "Distance and Warning with Audio Functionality",
        "func": "var payload = msg.payload;\nlet topic1 = msg.topic;\nlet topic2 = msg.topic;\nvar payloadaudio = msg.payloadaudio;\nvar out;\n\nlet text = \"Increase Altitude\";\n\nflow.set('value', null);\n//if(topic != \"gas/0xWINKELBRUNN/gas_cmds/guidance/geofence/distance\"){\n   // msg.height_2 = \"arrow_downward\";\n    //msg.height = \"a\";\n    //msg.color = \"purple\";\n    //return msg;\n//}\n\nif(topic1 == \"gas/uas/0xWINKELBRUNN/gas_cmds/guidance/geofence/distance\"){\n    msg.navigation = \"flight\";\n    msg.indicator_color = \"red\";\n    msg.value = parseFloat(payload).toFixed(2);\n    msg.height_1 = \"arrow_upward\";\n    msg.height = \"X\";\n    msg.color = \"red\";\n    out = JSON.stringify(text);\n    msg.payloadaudio = out;\n    return msg;\n}\n\nif(topic2 == \"gas/uas/0xWINKELBRUNN/gas_cmds/warning/geofence\"){\n    var distance = flow.get('value');\n    msg.value = distance;\n    return msg;\n}\n\n//else{\n  //  msg.reset = true;\n   // return msg;\n//}\n\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 400,
                "13277dd1d6135de0",
                "c2cc9d2c52c4fbeb",
                "bb3a101222697f35",
                "df70d532008d85c3",
                "b7e541c6cf59bc5b"
        "id": "b7e541c6cf59bc5b",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1050,
        "y": 320,
        "id": "0d8cb293d6660787",
        "type": "mqtt in",
        "topic": "gas/uas/0xWINKELBRUNN/gas_cmds/warning/geofence",
        "qos": "0",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 210,
        "y": 520,
                "05a6f4081d8bd503",
                "ea3f127edfabea20",
                "7e3d5f575013bbce"
        "id": "05a6f4081d8bd503",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 210,
        "y": 620,
        "id": "ea3f127edfabea20",
        "type": "function",
        "name": "Geofence Trigger",
        "func": "var payload = msg.payload;\nvar topic = msg.topic;\n\nif(topic == \"gas/uas/0xWINKELBRUNN/gas_cmds/warning/geofence\"){\n    msg.geofence = payload;\n}\nif(msg.payload == false){\n  msg.reset = true;\n}\nreturn msg;\n\n\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 570,
        "y": 520,
                "8866a4cbaf06df87",
                "50cac0e3e57c33cc"
        "id": "df70d532008d85c3",
        "type": "change",
        "name": "Set to payloadaudio",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payloadaudio",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 840,
        "y": 500,
                "50cac0e3e57c33cc"
        "id": "f8cbfb25e1061605",
        "type": "function",
        "name": "function 1",
        "func": "let payload = msg.payload;\nlet topic = msg.topic;\nlet out;\nlet payloadauido = msg.payloadaudio;\nlet text = \"Stable\";\nmsg.topic = \"gas/uas/0xWINKELBRUNN/gas_cmds/flight_state\";\n\nif(msg.payload == \"yellow\"){\n    out = JSON.stringify(text);\n    msg.payloadaudio = out;\n    return msg;\n}\nif(msg.payload == \"green\"){\n    msg.reset = true;\n    return msg;\n}",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 440,
        "y": 120,
                "e799758c82d482c3"
        "id": "e799758c82d482c3",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 600,
        "y": 120,
                "466927c18ab520d8"
        "id": "91982b09e6f2dce3",
        "type": "worldmap",
        "lat": "2.9",
        "lon": "6.8",
        "zoom": "4",
        "layer": "OSMC",
        "cluster": "4",
        "maxage": "1",
        "usermenu": "show",
        "layers": "show",
        "panit": "true",
        "panlock": "false",
        "zoomlock": "false",
        "hiderightclick": "false",
        "coords": "deg",
        "showgrid": "false",
        "allowFileDrop": "false",
        "path": "/worldmap",
        "overlist": "DR,CO,RA,DN,AC,TL,HM",
        "maplist": "OSMG,OSMC,EsriC,EsriS,EsriT,EsriDG,UKOS",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 1220,
        "y": 80,
        "id": "d91430ed79438eec",
        "type": "worldmap-tracks",
        "depth": "10",
        "layer": "single",
        "smooth": true,
        "x": 930,
        "y": 80,
                "91982b09e6f2dce3"
        "id": "bb3a101222697f35",
        "type": "ui_text",
        "group": "1b60bd173cfedbb2",
        "order": 8,
        "width": 0,
        "height": 0,
        "name": "Display Message",
        "label": "",
        "format": "{{msg.payloadaudio}} ",
        "layout": "row-center",
        "className": "",
        "x": 1130,
        "y": 500,
        "id": "bd4e5771559f76c8",
        "type": "ui_gauge",
        "order": 7,
        "width": 6,
        "height": 4,
        "gtype": "compass",
        "title": "Navigation",
        "label": "Degrees",
        "format": "{{msg.direction}}",
        "min": 0,
        "max": "10",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 1190,
        "y": 160,
        "id": "50cac0e3e57c33cc",
        "type": "ui_audio",
        "d": true,
        "name": "Audio on Dashboard",
        "voice": "Google US English",
        "always": true,
        "x": 1140,
        "y": 540,
        "id": "466927c18ab520d8",
        "type": "ui_audio",
        "d": true,
        "always": "",
        "x": 680,
        "y": 160,
        "id": "94f9e96c39bc49e1",
        "type": "ui_template",
        "name": "Flight_Status",
        "order": 2,
        "width": 7,
        "height": 4,
        "format": "<style>\n\n    #flight_status {\n        background:{{msg.indicator_color}};\n        font-size: 72px;\n        \n        border-radius: 50%;\n        text-align:right;\n        \n        transition-duration: 8s;\n        transition-property: transform;\n        transform: rotate({{msg.direction}}deg);\n    }\n    \n    .navigation{\n        display:flex;\n        position:absolute;\n        \n    }\n    .navigation_status{\n        margin-left:25px;\n        padding-top:10px;\n        padding-left:40px;\n        \n    }\n    \n    .flight_status{\n       margin-left:40px;\n       padding-top:20px;\n    \n    }\n    \n    @media screen (min-width:480px) and (orientation:landscape){\n        width: 480px;\n        height: 320px;\n        \n    }\n    @keyframes blinker{\n        50%{\n            opacity:0;\n        }\n        100%{\n            opacity:1;\n        }\n    }\n    @keyframes downwards{\n        0%{\n            opacity:0;\n        }\n        50%{\n            opacity:1; visibility:hidden;\n        }\n        100%{\n            opacity:0; \n        }\n    }\n    \n</style>\n\n<div class=\"navigation\">\n    <div class=\"flight_status\">\n        <table class= \"navigation_status\">\n            <tr>\n                <td><h3>Flight_Status:</h3></td>\n                <td><i class=\"material-icons\" id=\"flight_status\">{{msg.navigation}}</i></td>\n            </tr>\n        \n        </table>\n        \n    </div>\n\n</div>\n\n    \n<script>\n    //Create Label\n    //const label = document.createElement(\"label\");\n    //label.set attribute(\"for\", \"distance\");\n    //label.innerHTML = \"Distance: \"\n    \n    //insert label\n    //document.appendChild(label);\n\n    //create input\n    //const input = document.createElement(\"input\");\n    //input.setAttribute(\"id\",\"distance\");\n    //document.body.appendChild(input); //insert input\n    \n    //const distanceText = document.getElementbyId(\"distance\");\n   // distanceText.setAttribute(\"placeholder\", \"Distance in meters\");\n    \n    //const value = distanceText.value;\n    //console.log({{msg.value}});\n\n</script>\n\n\n",
        "storeOutMessages": false,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 990,
        "y": 200,
        "id": "13277dd1d6135de0",
        "name": "Geofence/Distance",
        "order": 3,
        "width": 5,
        "height": 2,
        "format": "<style>\n\n    .distance{\n        margin-left:30px;\n        float:right;\n        padding-top:25px;\n        display:flex;\n        position:absolute;\n        \n        \n    }\n    .distance_status{\n        padding-left:30px;\n    }\n    \n</style>\n\n\n\n<div class=\"distance\">\n    <table class=\"distance_status\">\n        <tr>\n            <td><h4>Distance to Exit: {{msg.value}} meters</h4></td>\n        </tr>\n            \n    </table>\n        \n</div>\n",
        "className": "",
        "x": 1150,
        "y": 380,
        "id": "fe77787841f182b0",
        "name": "Geofence/Direction",
        "order": 4,
        "width": 5,
        "height": 2,
        "format": "<style>\n\n    .direction{\n        margin-left:30px;\n        float:right;\n        position:static;\n        display:flex;\n        padding-top:10px;\n    }\n    \n    .direction_status{\n        padding-left:30px;\n        height:10px;\n    }\n\n</style>\n\n<div class=\"direction\">\n    <table class=\"direction_status\">\n        <tr>\n            <td><h4>Drone Direction: {{msg.direction}} Degrees</h4></td>\n        </tr>\n            \n    </table>\n        \n</div>\n    \n",
        "className": "",
        "x": 990,
        "y": 240,
        "id": "8866a4cbaf06df87",
        "name": "Warning/Geofence",
        "order": 5,
        "width": 6,
        "height": 1,
        "format": "<style>\n    .geofence{\n        display:inline-block;\n    }\n    .geofence_status{\n        margin-left:50px;\n        padding-left:20px;\n        \n    }\n</style>\n\n\n\n<div class= \"geofence\">\n    <table class = \"geofence_status\">\n        <tr>\n            <td><h4>Entering Geofence: {{msg.geofence}}</h4></td>\n        </tr>\n        \n    </table>\n    \n</div>",
        "className": "",
        "x": 870,
        "y": 600,
        "id": "c2cc9d2c52c4fbeb",
        "name": "Height_Status",
        "order": 1,
        "width": 3,
        "height": 4,
        "format": "<style>\n     #height_upwards{\n        font-size:72px;\n        text-align:center;\n        vertical-align:middle;\n        border-radius:50%;\n        background:{{msg.color}};\n        animation: blinker 1s linear infinite;\n    }\n    #height_downwards{\n        font-size:72px;\n        text-align:center;\n        vertical-align:middle;\n        border-radius:50%;\n        background:{{msg.color}};\n        animation: downwards 1s alternate infinite;\n        /*visibility:hidden;*/\n    }\n    #text{\n        position:relative;\n        text-align:center;\n        padding-top:1px;\n    }\n    #height_downwards{\n        position:relative;\n        top:30px;\n    \n    }\n     .height{\n       display:flex;\n       margin-left:20px;\n       width:50%;\n        \n    }\n    \n</style>\n\n<div class=\"height\">\n    <table class=\"height_status\">\n        <tr>\n            <td><h3>Height:</h3></td>\n        </tr>\n        <tr>\n            <td><i class=\"material-icons\" id=\"height_upwards\">{{msg.height_1}}</i></td>\n        </tr>\n        <tr>\n            <td id= \"text\"><h4>{{msg.height}} meters</h4></td>\n        </tr>\n        <tr>\n            <td><i class=\"material-icons\" id=\"height_downwards\">{{msg.height_2}}</i></td>\n        </tr>\n            \n    </table>\n        \n</div>",
        "storeOutMessages": true,
        "className": "",
        "x": 1180,
        "y": 440,
        "id": "4270807e778dbf05",
        "type": "ui_worldmap",
        "order": 6,
        "width": 9,
        "height": 5,
        "lat": "2.9",
        "lon": "6.8",
        "zoom": "4",
        "layer": "OSMG",
        "cluster": "4",
        "maxage": "1",
        "usermenu": "hide",
        "layers": "hide",
        "panit": "true",
        "panlock": "false",
        "hiderightclick": "true",
        "coords": "deg",
        "overlist": "DR,CO,RA,DN,HM",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 840,
        "y": 40,
        "id": "a635293a09a88a33",
        "type": "mqtt-broker",
        "name": "SIMULU - Standard pub/sub",
        "broker": "wss://mqtt.simulu.app",
        "port": "443",
        "tls": "ca1efa415c070b56",
        "clientid": "",
        "autoConnect": true,
        "usetls": true,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "1b60bd173cfedbb2",
        "type": "ui_group",
        "name": "User_Interface",
        "tab": "a50c557d2ff0efa6",
        "order": 1,
        "disp": true,
        "width": 15,
        "collapse": false,
        "className": ""
        "id": "ca1efa415c070b56",
        "type": "tls-config",
        "cert": "",
        "key": "",
        "ca": "",
        "certname": "",
        "keyname": "",
        "caname": "",
        "servername": "",
        "verifyservercert": true,
        "alpnprotocol": ""
        "id": "a50c557d2ff0efa6",
        "type": "ui_tab",
        "name": "SIMULU",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
No idea, as i do not have world map installed.
Having a quick read of the docs, you would just need to send the new coordinates with the unique name and the point should move i beleive.
name must be a unique identifier across the whole map. Repeated location updates to the same name move the marker.
