Hello my friends, I want to display two values on two different sections of my dashboard.
knowing that the values are the same, the two sections are one automatic and the other manual mode,
everytime the sensor sends the data, I can see the two gauges filling, but I only need one filling, according to the topic either it's automatic or manual! and according to the button of that section, if i clicked on launch from the manual section , the gauge of the manual section has to start filling, if I clicked on launch from the automatic section, the gauge of the automatic section has to start filling.
Here's the flow:
"id": "5daee7dea76bfee7",
"type": "ui_button",
"z": "9c063dfd0b542ce5",
"group": "d9096ae79b00f8d1",
"order": 4,
"width": 0,
"height": 0,
"passthru": true,
"label": "Launch ",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "play_arrow",
"payload": "Launch",
"payloadType": "str",
"topic": "esp32/button/manual",
"topicType": "msg",
"x": 620,
"y": 640,
"9556e593582f1358",
"27c8ed3c5fceb8f9"
"id": "9556e593582f1358",
"type": "mqtt out",
"name": "manual",
"qos": "1",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "21cdba4a.be7146",
"x": 1160,
"y": 460,
"id": "69447b19893b4464",
"type": "ui_gauge",
"name": "Manual rate",
"order": 1,
"width": "0",
"height": "0",
"gtype": "gage",
"title": "Flow Rate",
"label": "mL/s",
"format": "{{value}}",
"min": "0",
"max": "100",
"colors": [
"#eb2ddc",
"#5a2656",
"#a3009e"
"seg1": "",
"seg2": "",
"className": "",
"x": 1150,
"y": 320,
"id": "4cbe1f9ae3e9bfa9",
"name": "Stop",
"order": 5,
"width": 0,
"height": 0,
"passthru": false,
"label": "Stop",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "stop",
"payload": "Stop",
"topicType": "msg",
"x": 610,
"y": 760,
"9556e593582f1358",
"49ac6cd4beb2dc6a"
"id": "6d19f5f6798b9551",
"name": "Reset",
"order": 6,
"width": 0,
"height": 0,
"passthru": false,
"label": "Reset",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "replay",
"payload": "Reset",
"topicType": "msg",
"x": 630,
"y": 700,
"9556e593582f1358",
"575de01b18c53262"
"id": "8d639083c1b0f54b",
"type": "ui_gauge",
"name": "Manual volume",
"order": 2,
"width": 0,
"height": 0,
"gtype": "wave",
"title": "Volume",
"label": "mL",
"min": 0,
"max": "1000",
"colors": [
"#00b500",
"#e6e600",
"#ca3838"
"seg1": "",
"seg2": "",
"className": "",
"x": 1000,
"y": 140,
"id": "4d251917f4fde7f3",
"type": "ui_ui_control",
"events": "all",
"x": 1340,
"y": 460,
"id": "27c8ed3c5fceb8f9",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1170,
"y": 700,
"id": "49ac6cd4beb2dc6a",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1170,
"y": 820,
"id": "575de01b18c53262",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1170,
"y": 760,
"id": "e275989cf9b7d2f6",
"type": "ui_gauge",
"name": "Automatic volume",
"group": "e739c1d1a4a831b3",
"order": 3,
"width": 0,
"height": 0,
"gtype": "wave",
"title": "Volume",
"label": "mL",
"min": 0,
"max": "1000",
"colors": [
"#00b500",
"#e6e600",
"#ca3838"
"seg1": "",
"seg2": "",
"className": "",
"x": 1010,
"y": 200,
"id": "023fe43a623178d1",
"type": "ui_chart",
"name": "Automatic rate",
"order": 4,
"width": "6",
"height": "5",
"label": "chart",
"chartType": "line",
"legend": "true",
"xformat": "Time(s)",
"interpolate": "linear",
"nodata": "",
"dot": true,
"ymin": "0",
"ymax": "100",
"removeOlder": 1,
"removeOlderPoints": "",
"removeOlderUnit": "1",
"cutout": 0,
"useOneColor": false,
"useUTC": false,
"colors": [
"#355f7e",
"#aec7e8",
"#e198d4",
"#f15050",
"#a4ee68",
"#f93939",
"#ff9896",
"#ae67bc",
"#8c789b"
"outputs": 1,
"useDifferentColor": false,
"className": "",
"x": 1140,
"y": 260,
"id": "5e279a0640b6ebb7",
"type": "mqtt out",
"name": "automatic",
"topic": "input/button/volume",
"qos": "1",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 1160,
"y": 380,
"id": "4340261698c53f9b",
"type": "ui_text_input",
"label": "",
"tooltip": "",
"order": 2,
"width": 0,
"height": 0,
"passthru": true,
"mode": "number",
"delay": "1000",
"topic": "number",
"sendOnBlur": true,
"topicType": "str",
"x": 330,
"y": 440,
"6b303251a8080ef5"
"id": "6b303251a8080ef5",
"type": "rbe",
"func": "rbe",
"gap": "",
"start": "",
"inout": "out",
"septopics": true,
"property": "payload",
"topi": "topic",
"x": 550,
"y": 540,
"13624e792d99e806"
"id": "de9929f1e80e542b",
"type": "rbe",
"func": "rbe",
"gap": "",
"start": "",
"inout": "out",
"septopics": true,
"topi": "topic",
"x": 610,
"y": 440,
"d535b4076f8bea2a"
"id": "d535b4076f8bea2a",
"type": "join",
"mode": "custom",
"build": "object",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": true,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 910,
"y": 440,
"f0d2f47e2437d262"
"id": "f0d2f47e2437d262",
"type": "function",
"name": "Comparison",
"func": "msg.payload = msg.payload.auto_vol >= msg.payload.number\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1170,
"y": 540,
"0cbd47fd7278b6db"
"id": "13624e792d99e806",
"type": "switch",
"name": "IF in (1..1000)",
"rules": [
"t": "btwn",
"v": "1",
"vt": "num",
"v2": "1000",
"v2t": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 740,
"y": 520,
"d535b4076f8bea2a",
"4417a7ba2d84560d"
"id": "ca5314487849f769",
"type": "ui_template",
"name": "Enter volume:",
"order": 1,
"width": 6,
"height": 1,
"format": "<p>Enter volume: </p>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 300,
"y": 540,
"4340261698c53f9b"
"id": "0cbd47fd7278b6db",
"type": "debug",
"name": "true",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"x": 1230,
"y": 620,
"id": "4417a7ba2d84560d",
"type": "debug",
"name": "Display input",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1010,
"y": 620,
"id": "93e031041ba6c5fb",
"name": "Launch",
"order": 6,
"width": 0,
"height": 0,
"passthru": false,
"label": "Launch",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"payload": "Launch1",
"topicType": "msg",
"x": 600,
"y": 820,
"5e279a0640b6ebb7",
"7e25ca37381911f8"
"id": "7e25ca37381911f8",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1050,
"y": 880,
"id": "d1ef99e872ad142f",
"name": "Reset",
"order": 7,
"width": 0,
"height": 0,
"passthru": false,
"label": "Reset",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "replay",
"payload": "Reset",
"topicType": "msg",
"x": 590,
"y": 880,
"5e279a0640b6ebb7",
"98aca2806218da31"
"id": "98aca2806218da31",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1035.7142944335938,
"y": 935.7142944335938,
"id": "a1c9c2db0a24174a",
"type": "mqtt in",
"topic": "manual_vol",
"qos": "1",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"x": 430,
"y": 140,
"8d639083c1b0f54b"
"id": "23ea5642c50bd289",
"type": "mqtt in",
"topic": "auto_vol",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"x": 440,
"y": 200,
"e275989cf9b7d2f6",
"de9929f1e80e542b"
"id": "c3e272d5a76cfdea",
"type": "mqtt in",
"topic": "manual_rate",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"x": 390,
"y": 320,
"69447b19893b4464"
"id": "34016eda25718827",
"type": "mqtt in",
"topic": "auto_rate",
"qos": "2",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"x": 400,
"y": 260,
"023fe43a623178d1"
"id": "d9096ae79b00f8d1",
"type": "ui_group",
"name": "Manual",
"tab": "e9d3ea7203cc93cc",
"order": 3,
"disp": true,
"width": "6",
"collapse": true,
"className": ""
"id": "21cdba4a.be7146",
"type": "mqtt-broker",
"broker": " 192.168.1.16",
"port": "1883",
"clientid": "",
"usetls": false,
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"willTopic": "",
"willQos": "0",
"willPayload": ""
"id": "e739c1d1a4a831b3",
"type": "ui_group",
"name": "Automatic_B",
"tab": "fb7aed5ada447f07",
"order": 2,
"disp": true,
"width": "6",
"collapse": true,
"className": ""
"id": "e9d3ea7203cc93cc",
"type": "ui_tab",
"name": "Water control: Manual",
"icon": "fa-tint",
"disabled": false,
"hidden": false,
"info": "`<i class=\"fa fa-tint\" aria-hidden=\"true\"></i>`"
"id": "fb7aed5ada447f07",
"type": "ui_tab",
"name": "Water control: Automatic_B",
"icon": "fa-tint",
"order": 7,
"disabled": false,
"hidden": false
