How to display the output from the barcode scanned at the dashboard?
Hi, how to display the output of a barcode to be shown at the the dashboard. I have a scanner connected to my laptop with usb cable.
This is my flow. Can anyone help me to solve it?
        "id": "5bb019b65d5f0af7",
        "type": "inject",
        "z": "11b31e36b98445ad",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 220,
        "y": 220,
                "f62c2ee556bf4e86"
        "id": "f62c2ee556bf4e86",
        "type": "Barcode Generator",
        "data": "www.google.com",
        "dataType": "str",
        "barcode": "qrcode",
        "barcodeType": "barcode",
        "options": "",
        "optionsType": "ui",
        "sendProperty": "payload",
        "props": [
                "p": "rotate",
                "v": "N",
                "vt": "str"
                "p": "includetext",
                "v": "true",
                "vt": "bool"
                "p": "textxalign",
                "v": "center",
                "vt": "str"
        "x": 370,
        "y": 220,
                "72583360f1fa1443"
        "id": "72583360f1fa1443",
        "type": "jimp-image",
        "data": "payload",
        "dataType": "msg",
        "ret": "b64",
        "parameter1": "",
        "parameter1Type": "msg",
        "parameter2": "",
        "parameter2Type": "msg",
        "parameter3": "",
        "parameter3Type": "msg",
        "parameter4": "",
        "parameter4Type": "msg",
        "parameter5": "",
        "parameter5Type": "msg",
        "parameter6": "",
        "parameter6Type": "msg",
        "parameter7": "",
        "parameter7Type": "msg",
        "parameter8": "",
        "parameter8Type": "msg",
        "sendPropertyType": "msg",
        "parameterCount": 0,
        "jimpFunction": "none",
        "selectedJimpFunction": {
            "name": "none",
            "fn": "none",
            "description": "Just loads the image.",
            "parameters": []
        "x": 520,
        "y": 220,
                "0f10978fe0469748"
        "id": "0f10978fe0469748",
        "type": "image viewer",
        "width": 160,
        "data": "payload",
        "dataType": "msg",
        "active": true,
        "x": 680,
        "y": 220,
                "eb155874df4dc7f4",
                "0ca185c4250bb856"
        "id": "eb155874df4dc7f4",
        "type": "ui_template",
        "group": "a348b0ef9d248038",
        "order": 3,
        "width": "6",
        "height": "5",
        "format": "<img src=\"{{msg.payload}}\" style=\"height: 100%;\" />",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 850,
        "y": 220,
        "id": "0ca185c4250bb856",
        "type": "ui_text_input",
        "label": "",
        "tooltip": "",
        "group": "9c6c51bf2c3ab5b9",
        "order": 0,
        "width": 0,
        "height": 0,
        "passthru": true,
        "mode": "text",
        "delay": 300,
        "topic": "topic",
        "sendOnBlur": true,
        "className": "",
        "topicType": "msg",
        "x": 820,
        "y": 120,
                "eb155874df4dc7f4",
                "6fc71cb400087d25"
        "id": "6fc71cb400087d25",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 810,
        "y": 60,
        "id": "a348b0ef9d248038",
        "type": "ui_group",
        "name": "Default",
        "tab": "3316deba5234ba30",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "9c6c51bf2c3ab5b9",
        "type": "ui_group",
        "name": "Scanner Output ",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "3316deba5234ba30",
        "type": "ui_tab",
        "name": "test",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
I see the output on the desktop without changing anything
I need to show the output by scanning the qrcode using scanner and my scanner connected to my laptop usb port.
Take a read of this thread. Look towards the bottom, it may help you out
Thank you
