please help me, how to make this circuit?
If timestamp2 is activated less than 30s aftertime stamp1, then output1; otherwise output 2.
To compare 2 values from different inputs - you need either a context to collect data or join them to one message object. Here is the second option to use one msg object:
The payload contains the timestamps of both Inject Nodes - as timestamp1 and timestamp2
"id": "caf33cc421d60cc9",
"type": "inject",
"z": "7fd8fff652f013f7",
"name": "timerstamp1",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "30",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "timestamp1",
"payload": "",
"payloadType": "date",
"x": 520,
"y": 2700,
"573e5c83f4c58711"
"id": "c045dc5af2c4ee14",
"type": "inject",
"name": "timestamp2",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "timestamp2",
"payload": "",
"x": 510,
"y": 2760,
"573e5c83f4c58711"
"id": "2ce6af9c4c69d452",
"type": "switch",
"property": "payload.timestamp2 - payload.timestamp1",
"propertyType": "jsonata",
"rules": [
"t": "btwn",
"v": "0",
"vt": "num",
"v2": "30000",
"v2t": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 910,
"y": 2760,
"0ecde1ec68971efd"
"18fa985cfca36a10"
"id": "573e5c83f4c58711",
"type": "join",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": true,
"timeout": "",
"count": "2",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 770,
"y": 2760,
"2ce6af9c4c69d452",
"1470b1c4d3b44a90"
"id": "0ecde1ec68971efd",
"type": "debug",
"name": "output1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1060,
"y": 2720,
"id": "18fa985cfca36a10",
"type": "debug",
"name": "output2",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1060,
"y": 2780,
"id": "1470b1c4d3b44a90",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.timestamp2 - payload.timestamp1",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 950,
"y": 2840,
"5a3c97e10e8b6332"
"id": "5a3c97e10e8b6332",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 1150,
"y": 2840,
The switch creates the difference and send the msg if between 0 and 30,000 ms to output 1 otherwise to output 2
Thanks. It seems to be what I need.
I also need to add a condition - if the timestamp1 is not activated at all, but the timestamp2 is activated, then the output2.
Yes, but then activating timestamp1 also results in output2. I need to process only the timestamp2. Add a filter?
No, not like this. Timestamp1 is only a condition for timestamp2. There should be no action after it.
This will work as it should. But after each deployment, the first hit will be incorrect.
Ok - so you there is a strict order.
I fear you need a function node.
I try to implement this.
Would adding a msg.complete to timestamp2 do what you need.
e.g.
[{"id":"caf33cc421d60cc9","type":"inject","z":"bf9e1e33.030598","name":"timerstamp1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"timestamp1","payload":"","payloadType":"date","x":100,"y":80,"wires":[["573e5c83f4c58711"]]},{"id":"573e5c83f4c58711","type":"join","z":"bf9e1e33.030598","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":360,"y":140,"wires":[["2ce6af9c4c69d452"]]},{"id":"c045dc5af2c4ee14","type":"inject","z":"bf9e1e33.030598","name":"timestamp2","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"complete","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"timestamp2","payload":"","payloadType":"date","x":100,"y":140,"wires":[["573e5c83f4c58711"]]},{"id":"2ce6af9c4c69d452","type":"switch","z":"bf9e1e33.030598","name":"","property":"$abs(payload.timestamp1 - payload.timestamp2)","propertyType":"jsonata","rules":[{"t":"btwn","v":"0","vt":"num","v2":"5000","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":500,"y":140,"wires":[["0ecde1ec68971efd"],["18fa985cfca36a10"]]},{"id":"0ecde1ec68971efd","type":"debug","z":"bf9e1e33.030598","name":"output1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":100,"wires":[]},{"id":"18fa985cfca36a10","type":"debug","z":"bf9e1e33.030598","name":"output2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":160,"wires":[]}]
so here a variant with a function node:
"id": "55a36a4283820f43",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"payload": "",
"x": 310,
"y": 3160,
"24a3e35cd8a39b34"
"id": "e09fb12e0bc4fa10",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"payload": "",
"x": 310,
"y": 3240,
"24a3e35cd8a39b34"
"id": "24a3e35cd8a39b34",
"type": "function",
"func": "if (msg.topic === \"timestamp1\") context.set(\"t1\",msg.payload);\n\nif (msg.topic === \"timestamp2\"){\n var ts1 = context.get(\"t1\");\n if (ts1 === undefined) return [null, msg]; else {\n context.set (\"t1\", undefined);\n if (msg.payload - ts1 >= 0 && msg.payload - ts1 <= 30000) return [msg,null]; else return [null, msg];\n }\n}\n",
"outputs": 2,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 500,
"y": 3200,
"39598c3dda919b38"
"bc5efa4cf2803c2e"
"id": "39598c3dda919b38",
"type": "debug",
"name": "output1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 700,
"y": 3160,
"id": "bc5efa4cf2803c2e",
"type": "debug",
"name": "output2",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 700,
"y": 3220,
Yes. Looks like this is exactly what I need.
And I already began to invent too difficult:
[{"id":"caf33cc421d60cc9","type":"inject","z":"91dceac70a0f544f","name":"timerstamp1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"timestamp1","payload":"","payloadType":"date","x":130,"y":320,"wires":[["573e5c83f4c58711"]]},{"id":"c045dc5af2c4ee14","type":"inject","z":"91dceac70a0f544f","name":"timestamp2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"timestamp2","payload":"","payloadType":"date","x":130,"y":380,"wires":[["573e5c83f4c58711"]]},{"id":"2ce6af9c4c69d452","type":"switch","z":"91dceac70a0f544f","name":"","property":"payload.timestamp2 - payload.timestamp1","propertyType":"jsonata","rules":[{"t":"btwn","v":"0","vt":"num","v2":"30000","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":380,"wires":[["0ecde1ec68971efd"],["2e7ce5c7e23c7d80"]]},{"id":"573e5c83f4c58711","type":"join","z":"91dceac70a0f544f","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":380,"wires":[["2ce6af9c4c69d452"]]},{"id":"0ecde1ec68971efd","type":"debug","z":"91dceac70a0f544f","name":"output1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":340,"wires":[]},{"id":"18fa985cfca36a10","type":"debug","z":"91dceac70a0f544f","name":"output2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":900,"y":400,"wires":[]},{"id":"2e7ce5c7e23c7d80","type":"switch","z":"91dceac70a0f544f","name":"","property":"topic","propertyType":"msg","rules":[{"t":"cont","v":"timestamp2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":750,"y":400,"wires":[["18fa985cfca36a10"]]}]
Ok yours @E1cid is smarter. ![]()
