Hello
I am looking for a way to extract (multiple) images from a pdf file.
I don`t want to convert, I need to extract.
Hello
You will need to start by looking at how to do it with node.js
Then you can either build a node around the solution or you may be able to get away with requiring a libary in your settings.js file and passing it to a function node via the globals.
You can easily extract the images from PDF with the manual procedures.
For more info:- Extract image from PDF files
