How to insert the output of the buffer node to mysql db
Am not able to insert the value which is coming out of the buffer parser node into the local db (mariadb).
please find below flow and debug window
function node program
buffer parser
Appreciate , if some one help me in resolving it
thank you !
Why is the function node accessing values from msg.payload.Rows[i].V1 when your data (output from the buffer parser) is in msg.payload.V1?
The output from the modbus node will be 1 buffer. You correctly turn those into values V1~V3
Next you simply need to format the SQL insert. I don't understand what the function looping is supposed to be doing (looks like a copy and paste job)
thanks for the quick reply .
sorry , am new to node red and program
appreciate your help , if you can verify the following program
var topic =msg.topic;
var a = msg.payload.V1;
var b = msg.payload.V2;
var c = msg.payload.V3;
payload = 'INSERT INTO meter(V1,V2,V3) VALUES ("a","b","c")'
msg.payload=payload;
return msg
The function node with the red triangle has a syntax error in it. It should be marked if you open it and look.
That is certainly closer however you need to read the help info for the SQL node on the right-hand sidebar - it will tell you how to pass a SQL command.
To get you moving, this will likely be closer (but you need to understand how to correctly pass parameters to the SQL node to avoid possible SQL injection hacks)...
msg.topic = `INSERT INTO meter(V1,V2,V3) VALUES (${a}, ${b}, ${c})`
Doesn't the query go in the topic?
Doh. I forgot to edit that bit.
Edit...
Updated the sample code.
Thank you Steve-Mcl and Colin for your responses :grinning:
Along with Steve sample query , additional lines added in query. Initially the flow was successfully deployed and got output in DB too..
var sql =' ';
var outputs = ;
sql = 'INSERT INTO meter (V1,V2,V3) VALUE ({a},{b},${c})'
outputs.push({topic:sql});
return [ outputs ];
Another issue is raised :
"Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '{a},{b},{c})' at line 1"
thank you !
Energycharges
Check the example I posted. I used ` backticks around the string. This is known as a template literal. This is what makes ${a} turn into a variable value.
You didn't. You used single quotes and you missed out the $ symbol...
That was a mistake caused while posting the issue. Query was
sql = 'INSERT INTO meter (V1,V2,V3) VALUE (${a},${b},${c}).
Thank you for sharing me , Template _literals reference.
Appreciate , your effort in notifying the issue
thank you !
Energycharges
Thank you Steve for your timely response. :grinning:
updated query:
var sql ="";
var outputs = ;
sql = 'INSERT INTO meter (V1,V2,V3) VALUES ({a},{b},${c})'
return [ outputs ];
Issue raised:
thank you !
Energycharges
Issue :
var sql=" ";
var outputs = ;
sql = 'INSERT INTO meter ( V1,V2,V3) VALUES ({a}, {b}, ${c})';
return [outputs];
Energycharges
This is still wrong.
You need to use backticks and$ symbols for all of the variables..
sql =`INSERT INTO meter (V1,V2,V3) VALUES (${a},${b},${c})`
Thank you Steve :smiley: :smiley: for your timely help.
Thank you
Energycharges
