How to install node types?
I'm new to node-red, and I need help with installing node types.
When I run the project it says:
Flows stopped due to missing node types.
sf:3f24e8e108a6d3cc
sf:827ff8967a4e86f6
And I have them in separate folder, in main project folder (.node-red), in package.json I have included them(setworkmode and uimonad).
    "name": "node-red-project",
    "description": "A Node-RED Project",
    "version": "0.0.1",
    "private": true,
    "dependencies": {
        "node-red-contrib-bigexec": "~1.3.3",
        "node-red-contrib-modbus": "~5.23.1",
        "node-red-contrib-ui-contextmenu": "~2.0.1",
        "node-red-contrib-ui-led": "~0.4.11",
        "node-red-contrib-ui-multistate-switch": "~1.2.3",
        "node-red-dashboard": "~3.1.7",
        "setworkmode": "file:../subflowModules/setworkmode",
        "uimonad": "file:../subflowModules/uimonad"
Inside those 2 folders(setworkmode and uimonad) are index.js, package.json and subflow.json that former colleague has created.
And in CMD it says:
13 Apr 12:16:20 - [info] Waiting for missing types to be registered:
13 Apr 12:16:20 - [info]  - sf:3f24e8e108a6d3cc
13 Apr 12:16:20 - [info]  - sf:827ff8967a4e86f6```
Have you run npm install since adding them to package.json? You need to do that to get npm to create the necessary symlnks from /.node-red/node_modules to where the nodes are.
I have, but i get this:
C:\Users\Marko>npm install
npm ERR! code ENOENT
npm ERR! syscall open
npm ERR! path C:\Users\Marko/package.json
npm ERR! errno -4058
npm ERR! enoent ENOENT: no such file or directory, open 'C:\Users\Marko\package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR!     C:\Users\Marko\AppData\Local\npm-cache\_logs\2023-04-13T10_18_48_898Z-debug-0.log
I'm not 100% sure where files need to be located.
You need to run npm install in the same directory as your package.json file - .node-red
I did it like this:
C:\Users\Marko>npm install C:\Users\Marko\.node-red
removed 151 packages, changed 2 packages, and audited 164 packages in 4s
20 packages are looking for funding
  run `npm fund` for details
7 vulnerabilities (4 moderate, 3 high)
To address issues that do not require attention, run:
  npm audit fix
To address all issues, run:
  npm audit fix --force
Run `npm audit` for details.
But now I don't have any other nodes in palette except node-red and setworkmode, and more of the nodes in the project are red line dashed
That is not what I said to do.
You should run npm install from in the directory C:\Users\Marko\.node-red
cd C:\Users\Marko\.node-red
npm install
I did it like that now, but I'm still missing uimonad node in palette
What is in package.json?
In uimonad package.jason is:
  "name": "uimonad",
  "version": "1.0.0",
  "description": "Ensure UI text reacts to errors and fetch prompts.",
  "main": "index.js",
  "scripts": {
    "test": "echo \"Error: no test specified\" && exit 1"
  "keywords": [
    "monad",
    "error",
    "init",
    "ui"
  "author": "Toni Opuhač",
  "license": "ISC",
  "node-red": {
    "nodes": {
      "uimonad": "index.js"
    "dependencies": [
      "node-red-contrib-bigexec",
      "node-red-contrib-modbus",
      "node-red-contrib-ui-contextmenu",
      "node-red-contrib-ui-led",
      "node-red-contrib-ui-multistate-switch",
  "dependencies": {
    "node-red-dashboard": "^3.4.0"
As you can see, that is messed up. It may have been the incorrect npm install that you did earlier that caused that. Fix that, then I may be wrong, but I don't think it is a good idea to put the linked nodes under the .node-red folder, I think I had problems doing that at some point. Move them out to separate folders and remove those entries from package.json. Then to get the subflowmodules installed, go into the .node-red folder and run
npm install /path/to/subflowModules/setworkmode
and the same for the other one. Then restart node red.
If you are not sure how to fix package.json then delete it and the node_modules folder. Then restart node-red. It will complain that there are missing nodes. Install those again, which you can do from inside node-red, then manually install your nodes as described above and restart node-red.
Category changed to general as the post is not about "developing nodes" :grinning:
Could you explain to me from start, so 0, I just opened new project and I only want to install for example setworkmode node type, how do you do that? Things that I have are only folder setworkmode and inside are files:
index.js
 const fs = require("fs");
 const path = require("path");
 module.exports = function(RED) {
     const subflowFile = path.join(__dirname,"subflow.json");
     const subflowContents = fs.readFileSync(subflowFile);
     const subflowJSON = JSON.parse(subflowContents);
     RED.nodes.registerSubflow(subflowJSON);
package.json
  "name": "setworkmode",
  "version": "1.0.0",
  "description": "Set work mode of leCPS.",
  "main": "index.js",
  "scripts": {
  "keywords": [
    "leCPS",
    "work",
    "mode",
    "set"
  "license": "ISC",
  "node-red": {
    "nodes": {
      "Set work mode state": "index.js"
    "dependencies": [
        "node-red-dashboard",
        "uimonad"
  "dependencies": {
subflow.json
"id": "827ff8967a4e86f6",
"type": "subflow",
"name": "Set work mode state",
"info": "",
"category": "function",
"in": [
	"x": 40,
	"y": 140,
		"id": "7056865d556523f1"
"out": [
	"x": 750,
	"y": 140,
		"id": "352ddb6a0cdcfbab",
		"port": 0
		"id": "c348f6c2462bd906",
		"port": 0
		"id": "ca9ca3c8f60b1653",
		"port": 0
		"id": "8e980d04beae8cd6",
		"port": 0
"env": [],
"meta": {},
"color": "#FFAAAA",
"inputLabels": [
    "CPS modbus payload"
"outputLabels": [
    "Colored text representing state"
"icon": "node-red/swap.svg",
"flow": [
        "type": "template",
        "z": "827ff8967a4e86f6",
        "name": "Set state local-automatic",
        "field": "payload",
        "fieldType": "msg",
        "format": "json",
        "syntax": "mustache",
        "template": "{\n    \"color\": \"brown\",\n    \"valueText\": \"Trenutno stanje lokalnog-automatskog upravljanja\"\n}",
        "output": "json",
        "x": 470,
        "y": 80,
        "type": "template",
        "name": "Set state remote",
        "field": "payload",
        "fieldType": "msg",
        "format": "json",
        "template": "{\n    \"color\": \"blue\",\n    \"valueText\": \"Trenutno stanje daljinskog načina upravljanja\"\n} ",
        "output": "json",
        "x": 440,
        "y": 120,
        "type": "template",
        "name": "Set state local",
        "field": "payload",
        "fieldType": "msg",
        "format": "json",
        "template": "{\n    \"color\": \"green\",\n    \"valueText\": \"Trenutno stanje lokalnog načina upravljanja\"\n}",
        "output": "json",
        "x": 440,
        "y": 160,
        "type": "template",
        "name": "Set state undefined",
        "field": "payload",
        "fieldType": "msg",
        "format": "json",
        "template": "{\n    \"color\": \"purple\",\n    \"valueText\": \"Trenutno stanje nije ispravno definirano\"\n}",
        "output": "json",
        "x": 450,
        "y": 200,
        "id": "7056865d556523f1",
        "type": "switch",
        "name": "Check work mode state",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "0",
                "vt": "num"
                "t": "eq",
                "v": "1",
                "vt": "num"
                "t": "eq",
                "v": "2",
                "vt": "num"
                "t": "eq",
                "v": "3",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 4,
        "x": 210,
        "y": 140,
                "352ddb6a0cdcfbab"
                "c348f6c2462bd906"
                "ca9ca3c8f60b1653"
                "8e980d04beae8cd6"
Where do I need to put that folder and what do I need to type and where? Step-by-step please, I'm just starting so I don't know much.
Firstly, do not manually edit package.json. If you have already done that then start again.
To install your node, in a command window, cd to your .node-red folder and, as I said above, run
npm install /path/to/your/node
then restart node-red.
I also said that I think I have had problems if the node is under the .node-red folder so it may be best to move it out of there.
Thank you soo much, it worked
