How to line up md-checkbox with label?
I have the following in a template node and functionally it works fine.
But I cannot get the tick box to line up with the label(see pic) any ideas ?
<div layout="row" ng-repeat="item in msg.payload">
    <md-checkbox ng-model="item.value" aria-label={{item.name}}> {{item.name}} </md-checkbox>
</div>
<md-button ng-click="send(msg)">
    Refresh
</md-button>
Fix it with overriding dashboard styles.
Don't know the reason but the label is moved a bit down with this:
md-checkbox .md-label {
    position: absolute;
    top: 32%;
Everything lines up nicely if you override it like this:
        top:unset;
Thanks hotNipi !
I found that 2nd and 3rd buttons in the same template also drop lower than the first due to -
.nr-dashboard-theme .nr-dashboard-template .md-button:not(:first-of-type) {
    margin-top: 18px;
Seems odd, If this from something in standard NR dashboard CSS, I cannot think why its there as it just messes up the layout?
