kiran
1
In JS file of the custom node i want clear the interval of function when user remove/delete custom node in node red
I already add this code - >
this.on('close', function(removed, done) {
if (removed) {
if(interval) {
clearInterval(interval);
timer = false;
done();
in the example @kiran posted, it might have been that interval was not accessible.
try adding this to your custom node - see if you get a log entry....
console.log("this.on('close') happened!")
if (removed) {
console.log("node was removed!")
done();
NOTE: done() is a relatively new parameter - you should check it is available before calling it)
