best place to look is in the node's documentation see node-red-contrib-simple-gate
Here is a simple flow showing how it works:
[{"id":"b8777bb45a883fe0","type":"inject","z":"a28015d0574dbca4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":60,"wires":[["2409e9e194bacc83"]]},{"id":"544c85eb742490a1","type":"gate","z":"a28015d0574dbca4","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":570,"y":140,"wires":[["cb97c09d16c64da0"]]},{"id":"8b15f49302c08e75","type":"change","z":"a28015d0574dbca4","name":"open gate","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":120,"wires":[["544c85eb742490a1"]]},{"id":"cb97c09d16c64da0","type":"debug","z":"a28015d0574dbca4","name":"debug 26","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":780,"y":140,"wires":[]},{"id":"2409e9e194bacc83","type":"trigger","z":"a28015d0574dbca4","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"250","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":360,"y":60,"wires":[["550d654d2b728d34"]]},{"id":"550d654d2b728d34","type":"change","z":"a28015d0574dbca4","name":"close gate","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":60,"wires":[["544c85eb742490a1"]]},{"id":"f87b82817d7ac388","type":"inject","z":"a28015d0574dbca4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":120,"wires":[["8b15f49302c08e75"]]},{"id":"15d988adf9dbe9a5","type":"inject","z":"a28015d0574dbca4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":180,"wires":[["544c85eb742490a1"]]}]
as for the 'critical notivication' I'm not a Home Assistant user (nor are many here) so I can't help you with that part.
