How to "npm install" to a red-node in a docker?
My red-node is run via docker.
Then I see this addon: node-red-contrib-zigbee2mqtt (node) - Node-RED
  • "npm install" is certainly not something I can do in shell .. so where does this command go?
You are better off just using standard MTTQ nodes
thanks, by any chance, are you aware of a suitable example/tutorial/guide ?
My FlexDash docs have quite an extensive how-to for docker. Obviously it's geared towards FlexDash but it's really all about installing packages. But it may be more complexity than you want to deal with... Docker - FlexDash
A guide for what in particular?
If you mean information about mqtt then see this tutorial MQTT Essentials - All Core Concepts Explained
If you mean specifically about using it with zigbee2mqtt then the best thing to do is to install mqttexplorer on a pc on your network and then you can look to see what mqtt topics your devices use so you can easily access then from node red.
First off, you need to open a shell on the container:
docker exec -it name_of_node-red_docker /bin/bash
Then, from within the running container, you go to the user dir you mapped when the container was launched, typically /data
Inside you will have a node_modules directory, you cd into it, and run:
npm i node-red-contrib-zigbee2mqtt
