I have a value saved in the flow context. flow.secret = "mysecret1234". I want to pass this into a subflow environment variable $secret via the config panel. How do I do this?
Thank you
Thank you
You cannot. The env vars of a subflow are static/fixed to the value you enter when you create the instance. This is by design.
If you want to pass data into the subflow, attach it to the msg using a change node or function node.
Ahh, Ok. Thank you.
