TL;DR how to I pass variables from one sub-flow to a child sub-flow?
I am using a flow that already uses sub-flows; secrets and other config are passed to the sub-flows via environment variables (using the config panel.)
I want to be able to deploy this in different environments, so different secrets are required.
My initial thought was to take the entire flow, and extract that as a sub-flow to have all the variables and secrets defined in one place. However I don't know how to pass those variables through the the sub-flows.
Apologies if this doesn't make much sense. Any help would be greatly appreciated.
