Send variable to subflow
I have a subflow which requires to enter an env variable, like this:
Is there a way to send the variable "Playlist uri" from a node instead of manually?
can you not send the uri in a msg.property, then in your subflow check if msg.property is defined and if so use that, else use the env.get variable
Yes, thanks. I will do that way.
