This is the array, weather forcast that i want to put into a sql, i have dont have a clue how to do ![]()
The data coms from here GET: https://opendata-download-metfcst.smhi.se/api/category/pmp3g/version/2/geotype/point/lon/15/lat/57/data.json
I am afraid there is just not enough information or background to go on.
Before anyone can help, you would need to state which database you mean?
Why do you want to store the forecast in a database - how do you intend to access and use the data?
Your URL returns forecasts for 72 different time points - hourly to start with, 12-hourly for later days. So if you were to request the data just once a day, most of the data you stored in the db yesterday has been made redundant by the new forecast. Do you want to compare how the forecast for a specific time varies, or are you just interested in the most recent forecast?
Are you familiar with any flavour of SQL database?
Node-red can interact with several different databases, eg Microsoft SQL Server, Mariadb (= MySQL), PostgreSQL etc. Several non-SQL databases too. It makes sense to stick with the kind you know.
You will most likely need to install a contrib node for the specific database type.
What platform do you run Node-red on, and what platform will run the database server?
Hi.
Sorry i was busy whit other tings.
i try to be more clear.
I run Node-red 3,0,2 and MySQL Workbench 8,0
I will use the data for the latest forcast ( make own weather forcast to control the heat in large buildings)
But i am usless to stor data from arrays, don´t understand how to divide smrtly, and in same function like in this case both insert data and uppdate data.
I hope it was more cleat what i´m looking for ![]()
I see no need for a database if you are only using the latest forecast data.
