How to read/connect csv file to dashboard
I'm new to node-red, generating CSV LOG from device to display in dashboard.
Can someone help me and show the process?
thanks for your help.
Try lookiing at these threads, plenty of examples of how to load csv and send to dashboard table or chart or gauge, etc
https://discourse.nodered.org/search?expanded=true&q=csv%20to%20dashboard
If you get stuck post what you have tried, and people will point you in the right direction.
[edit]
form data in the thread you tacked onto Create a graph from csv with time and 6 columns - #5 by king
[{"id":"d3bbd1c0.07cec","type":"inject","z":"76163776.1d52b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"start","payloadType":"date","x":330,"y":120,"wires":[["b1edd399.9488e8"]]},{"id":"b1edd399.9488e8","type":"template","z":"76163776.1d52b","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"AGVName,Date,Time,B1C1,B1C2,B1Temp,Current,SOC\n107102,2022/2/8,00:04.8,3.427,3.477,33,192.7,61\n107102,2022/2/8,00:11.7,8.449,3.503,33,193.2,61\n107102,2022/2/8,00:18.5,3.466,3.524,33,192.9,62\n107102,2022/2/8,00:25.3,3.474,3.536,33,192.7,62\n107102,2022/2/8,00:32.2,3.481,3.545,33,193,62\n107102,2022/2/8,00:39.0,3.361,3.384,33,-20.9,63\n107102,2022/2/8,00:45.9,3.341,3.365,33,-13.8,63\n107102,2022/2/8,00:52.7,3.326,3.343,33,-14.2,63\n107102,2022/2/8,00:59.6,3.312,3.326,33,-14.7,63\n107102,2022/2/8,01:06.5,3.306,3.313,33,-13.8,63\n107102,2022/2/8,01:13.3,3.299,3.305,33,-15.9,63\n107102,2022/2/8,01:20.2,3.291,3.291,33,-18.9,63\n107102,2022/2/8,01:27.0,3.286,3.283,33,-15.7,63\n107102,2022/2/8,01:33.9,3.288,3.284,33,-13.4,63\n107102,2022/2/8,01:40.7,3.288,3.283,33,-12.4,63\n107102,2022/2/8,01:47.6,3.281,3.27,33,-19.9,63\n107102,2022/2/8,01:54.5,3.279,3.267,33,-17.1,63\n107102,2022/2/8,02:01.3,3.278,3.265,33,-17.7,63\n107102,2022/2/8,02:08.1,3.276,3.262,33,-19.1,63\n107102,2022/2/8,02:15.0,3.276,3.262,33,-16.3,63\n107102,2022/2/8,02:22.6,3.279,3.267,33,-13.2,63\n107102,2022/2/8,02:29.4,3.278,3.265,33,-13.8,63\n107102,2022/2/8,02:36.3,3.278,3.267,33,-12.8,63\n107102,2022/2/8,02:43.1,3.277,3.264,33,-14,63\n107102,2022/2/8,02:50.0,3.277,3.264,33,-14,63\n107102,2022/2/8,02:56.8,3.276,3.263,33,-12.2,63\n107102,2022/2/8,03:03.7,3.279,3.267,33,-11.4,63\n107102,2022/2/8,03:10.5,3.267,3.248,33,-10.2,63\n107102,2022/2/8,03:17.3,3.277,3.265,33,-10.4,63\n107102,2022/2/8,03:24.2,3.277,3.265,33,-10,63\n107102,2022/2/8,03:31.0,3.269,3.254,33,-20.9,63\n107102,2022/2/8,03:37.8,3.272,3.257,33,-16.9,63\n107102,2022/2/8,03:44.6,3.273,3.259,33,-14.2,63\n107102,2022/2/8,03:51.5,3.268,3.252,33,-22.4,63\n","output":"str","x":400,"y":180,"wires":[["bc6a4158.0d8508"]]},{"id":"bc6a4158.0d8508","type":"csv","z":"76163776.1d52b","name":"csv","sep":",","hdrin":true,"hdrout":"all","multi":"mult","ret":"\\n","temp":"AGV,Date,Time,B1C1,B1C2,B1Temp, Current,SOC","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":550,"y":180,"wires":[["c0ba397e.0b979","d37e1783.2a496"]]},{"id":"c0ba397e.0b979","type":"debug","z":"76163776.1d52b","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":140,"wires":[]},{"id":"d37e1783.2a496","type":"function","z":"76163776.1d52b","name":"graph generate","func":"let payload=msg.payload;\n\nlet data = [[],[],[],[],[]];\nfor(let i=0;i<payload.length;i++){\n    let date = payload[i].Date.split(\"/\");\n    date[1] = date[1].padStart(2,\"0\");\n    date[2] = date[2].padStart(2,\"0\");\n    date = date.join(\"-\")\n    let time = payload[i].Time.split(\".\");\n    time[1] =time[1].padStart(2,\"0\");\n    time = time.join(\":\");\n     time = new Date(date+\"T\"+time);\n    data[0].push({\"x\": time, \"y\": payload[i].B1C1});\n    data[1].push({\"x\": time, \"y\": payload[i].B1C2});\n    data[2].push({\"x\": time, \"y\": payload[i].B1Temp});\n    data[3].push({\"x\": time, \"y\": payload[i].Current});\n    data[4].push({\"x\": time, \"y\": payload[i].SOC});\n}\nlet labels = msg.columns.split(\",\").slice(3);\nmsg.soc=data[4][data[4].length-1].y\nnode.warn(msg.soc)\nmsg.payload=[{\n\"series\": labels,\n\"data\":data,\n\"labels\": labels\n}];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":730,"y":180,"wires":[["1f0031ad.1f2e0e","8c626d16.8159c8"]]},{"id":"1f0031ad.1f2e0e","type":"ui_chart","z":"76163776.1d52b","name":"","group":"2ac8e3fa.8b8584","order":5,"width":0,"height":0,"label":"Time Graph Test","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#400000","#ff8000","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":960,"y":180,"wires":[["c1e06cd1.e2299"]]},{"id":"8c626d16.8159c8","type":"debug","z":"76163776.1d52b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":300,"wires":[]},{"id":"c1e06cd1.e2299","type":"ui_gauge","z":"76163776.1d52b","name":"","group":"2ac8e3fa.8b8584","order":2,"width":0,"height":0,"gtype":"wave","title":"SOC","label":"units","format":"{{msg.soc}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"","x":1150,"y":180,"wires":[]},{"id":"2ac8e3fa.8b8584","type":"ui_group","name":"Default","tab":"ebb1ed1c.5ebe2","order":1,"disp":true,"width":"12","collapse":false,"className":""},{"id":"ebb1ed1c.5ebe2","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
