Hi all,
I currently developing an application using Jointjs as the diagraming library. I have read the node-RED documents and I'd love to use node-RED runtime as the backend for my application.
Is it possible and where should I start? Even a document is enough. Github repo is even better.
Every suggestion is appreciated.
Thanks.
Did you read : Embedding into an existing app : Node-RED
Sure, node-red runtime is commanded by the node-red editor via HTTP so yes, it is possible.
Look up
to the top of this page (in the header)
Thanks for the answer.
I have read the document you sent me and skim through the main github repo.
If I understand the materials correctly, the steps to replace the frontend would be:
- Init node-RED runtime.
- Create a json flow similar to node-RED flow with the new frontend.
- post the flows to node-RED server with APIs in this document: Admin API Methods : Node-RED
Please correct me if I'm wrong somewhere.
In a nutshell, yes.
Thank you, initially I was stuck not knowing how to start the runtime alone. This document was very helpful. Embedding into an existing app : Node-RED
I have marked the solution.
