Hi All,
I'm following this guide to creating my first custom node. In the guide it states that ' Any changes to the node’s file can be picked up by simply restarting Node-RED' but does not provide any instruction on how to restart node red.
How can i restart node red when running on ubuntu?
Try opening a terminal window and entering node-red-restart and see if that works
Unfortunately that is not recognised. Only way I have been able to restart my has been to restart the PC.
Does
node-red-stop
Then
node-red-start
Work?
How did you install - did you used the official script?
hw do you start node-red? if youstart it in a terminal window, you should be able to get to that window and do a CTRL-C which should stop NR then enter node-red to start it again
https://nodered.org/docs/getting-started/windows#running-on-windows
no - node-red restart will start node-red with a flow called restart :-)... the command is node-red-restart.
Is Node-RED run via systemtd? In other words, it starts automatically on boot-up?
If so, you can restart it using systemctl restart node-red (note that the node-red part could be different if you created the init script yourself or used my alternate installer).
