After installing certain packages or modules it is recommended to restart node-red for the changes to take place. Could anyone help how to restart node-red on Windows 10 ?
Thanks.
Thanks.
How are you running Node-RED?
I ran node-red command on windows command prompt. And got an IP address, which I ran it in browser and now I am using that to run Node-red.
You can use ctrl-c in that command prompt will to end the process, or just close the command prompt window.
