How to rotate a text ui
Greetings everyone,
I would like to know whether the text ui in the dashboard able to rotate for -90° or not. Thanks in advance.
Best Regards.
This is my dashboard :
This is the example of rotated text dashboard found at the internet:
not sure if you are asking or showing us what you have done. If the former - I can't think of a way myself - if the latter then well done - please share !
Thank you for the reply.
No, I didn't. The second image is the one I found it on the internet, which I wish to achieve the same like it.
Can't say if it will be perfect but something like this can be done
[{"id":"61b6a155.7ef1b","type":"ui_template","z":"b633308d.4a91a","group":"2d39c4ed.6ee85c","name":"vertical text","order":1,"width":1,"height":"3","format":"<style>\n.rotated {\n    writing-mode: tb-rl;\n    transform: rotate(-180deg);\n    white-space: nowrap;\n    text-align: center;\n    margin: auto;\n    width: 50%;\n    font-weight:500;\n}\n</style>\n\n<div id=\"blue-rotated\" class=\"rotated\">ROTATED TEXT<div>\n    \n<script>\nfunction updateContainerStyle (el) {\n\tel = el.parentElement\n\tif (el && el.classList.contains('nr-dashboard-template')) {\n\t\tel.style.backgroundColor = \"#4c75db\";\n\t}\n}\nupdateContainerStyle(document.getElementById(\"blue-rotated\"))\n</script>\n\n    ","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":510,"y":220,"wires":[[]]},{"id":"2d39c4ed.6ee85c","type":"ui_group","z":"","name":"HOME","tab":"4486cc51.18fc44","order":1,"disp":true,"width":4,"collapse":false},{"id":"4486cc51.18fc44","type":"ui_tab","z":"","name":"TEST","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Yes, this should help too. Thank you for helping so much :pray:t2: :pray:t2:
Oh there was bug in that template,
fix this line
<div id="blue-rotated" class="rotated">ROTATED TEXT</div>
:rofl:Sorry for my stupid question, I had used your node and did for the rotation text. But I think the width is too large and which can be scroll, it there a way to reduce it?
My current dashboard :
May you try this then
<style>
.rotated {
    text-align: center;
    font-weight:500;
</style>
<div id="blue-rotated" class="rotated">{{msg.payload}}</div>
<script>
		el.style.background = "linear-gradient(90deg, rgba(76,184,254,1) 0%, rgba(21,128,219,1) 84%, rgba(39,125,215,1) 100%)";
		el.style.paddingTop = "36px";
        el.style.paddingLeft = "12px";
updateContainerStyle(document.getElementById("blue-rotated"))
</script>
Edit:
It will be better to adjust the container padding.
But you then need to finetune the vaules to get text centered
Now you made me to working on this. To get it work on dynamic content the previous thing also fails.
But there is better solution
[{"id":"61b6a155.7ef1b","type":"ui_template","z":"b633308d.4a91a","group":"2d39c4ed.6ee85c","name":"vertical text","order":1,"width":1,"height":"3","format":"<style>\n.rotated {\n    writing-mode: tb-rl;\n    white-space: nowrap;\n    font-weight:500;\n    margin: 0;\n    position: absolute;\n    top: 50%;\n    left: 50%;\n    margin-right: -50%;\n    transform: translate(-50%, -50%) rotate(-180deg)\n}\n</style>\n\n<div id=\"blue-rotated\" class=\"rotated\">{{msg.payload}}</div>\n    \n<script>\nfunction updateContainerStyle (el) {\n\tel = el.parentElement\n\tif (el && el.classList.contains('nr-dashboard-template')) {\n\t\tel.style.background = \"linear-gradient(90deg, rgba(76,184,254,1) 0%, rgba(21,128,219,1) 84%, rgba(39,125,215,1) 100%)\";\n\t}\n}\nupdateContainerStyle(document.getElementById(\"blue-rotated\"))\n</script>\n\n    ","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":390,"y":100,"wires":[[]]},{"id":"d78b0778.6cffa8","type":"inject","z":"b633308d.4a91a","name":"","topic":"","payload":"MEDIUM TEXT","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":80,"wires":[["61b6a155.7ef1b"]]},{"id":"88f31749.bb5268","type":"inject","z":"b633308d.4a91a","name":"","topic":"","payload":"TEXT","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":40,"wires":[["61b6a155.7ef1b"]]},{"id":"2e1ac32f.3fd39c","type":"inject","z":"b633308d.4a91a","name":"","topic":"","payload":"LONG LONG TEXT","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":120,"wires":[["61b6a155.7ef1b"]]},{"id":"2d39c4ed.6ee85c","type":"ui_group","z":"","name":"HOME","tab":"4486cc51.18fc44","order":1,"disp":true,"width":4,"collapse":false},{"id":"4486cc51.18fc44","type":"ui_tab","z":"","name":"TEST","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Yes, now it works! Thank you so much for the effort.:innocent: :innocent:
