How to run a node js app on my NR box?
Guys,
I have just found a Node.js app that is run from the command line as follows
node tuya-mqtt.js
This app lets me control and monitor my new heatpump system using mqtt
I run node red on a VM so have plenty of grunt and memory available - is there an easy way to get this app to run in the background on startup of the machine ?
I know this is not strictly a NR question - but doing a google search has led me down a rabbit warren and i do not want to bugger up the machine running my main NR flow
Craig
What OS are you running on?
If it is Debian based such as Ubuntu or Raspbian then a simple systemd script should do it.
Sorry - should have said.
yep Ubuntu based in a VM - 18LTS
regards
Craig
OK just going through now and trying to set it up as a service with systemd as the user pi
Working through a few issues now
Craig
If it just runs as root the "old fashioned easy way" is just to add it to /etc/rc.local - you would need to fully path both the executable and the script name but is an easy fix.
yeah seems to run fine as root - just trying to get it to run as a restricted user (pi) and having problems as it does not seem to understand paths to find the config files - just trying to work through permutations on that before i thrown in the towel and just run it as root
Craig
In fact it must be something i am doing/not understanding.
I can run it from the commandline as the pi user from within its own directory (under the home directory for the pi user) - but when i run it as a service it is having problems - must be something to do with paths to pass into the service - just trying to understand how to do that one
Craig
When you run from systemd, don't forget that you don't get any of the usual environment variables - like path. However, there are ways to inherit them if you need to. You'll need to look that up I'm afraid, systemd has too many options to just remember :grinning:
Yeah thanks Julian - i think it is the same boat i am in at the moment - just trying to work through the permutations to make that happen !
Craig
OK for anyone else that wants to use this nodejs app (which produces much cleaner output than the other Tuya apps i could find)
The solution i ended up finding was on the openhab forums
To create it as a service
To run tuya-mqtt as a systemd-service, you can create a file:
 sudo vi /lib/systemd/system/tuya-mqtt.service
and add the following lines:
 [Unit]
 Description=tuya-mqtt
 After=mosquitto.service
 [Service]
 ExecStart=/usr/bin/node /home/pi/tuya-mqtt/tuya-mqtt.js
 Restart=always
 User=pi
 Group=pi
 Environment=PATH=/usr/bin/
 Environment=NODE_ENV=production
 WorkingDirectory=/home/pi/tuya-mqtt/
 [Install]
 WantedBy=multi-user.target
After saving the file, you have to run:
 sudo systemctl daemon-reload
Now you can start the service:
 sudo systemctl start tuya-mqtt.service
Check if the service is runnning properly:
sudo systemctl status tuya-mqtt.service
Post #1 in this link
Craig
Do you really mean hom/pi on the execstart line ?
Good Spotting - sorry for the typo - fixed now !
Craig
Did you mean to include the space?
If you mean in between /usr/bin/node and then/home/pi etc etc
Then yes
It is saying to run the Node program and then run the javascript file in the tuya-mqtt directory (or are you saying there is another space somewhere ?
Craig
Don't you need to do sudo systemctl enable tuya-mqtt.service also if you want the thing to start at reboot
Yep - Exactly - i think that was in the link that i provided also - but good to point out thanks
Craig
