How to run flow fuse a service
I followed the guidelines as described in this link:
Running the FlowFuse Device Agent as a service on a Raspberry Pi • FlowFuse
Description=flowfuse Device Agent
Wants=network.target
Documentation=Documentation • FlowFuse
[Service]
Type=simple
Run as normal pi user - change to the user name you wish to run flowfuse Device as
User=root
Group=root
WorkingDirectory=/opt/flowfuse-device
Environment="NODE_OPTIONS=--max_old_space_size=512"
ExecStart=/usr/bin/env flowfuse-device-agent
Use SIGINT to stop
KillSignal=SIGINT
Auto restart on crash
Restart=on-failure
RestartSec=20
Tag things in the log
SyslogIdentifier=flowfuseDevice
#StandardOutput=syslog
[Install]
WantedBy=multi-user.target
Create the file service
sudo nano /etc/systemd/system/flowforge-device-agent.service
Paste the content from here.
Save and exit (ctrl + o then enter then ctrl + x)
Enable the service
sudo systemctl enable flowforge-device-agent.service
And finally start the service
sudo systemctl start flowforge-device-agent
