I'm using tasmota node for my 2 gang switch
How can I pick up the payload specifically from each button?
For the moment, I'm just using switch node to receive 'single','double' payload and so on but obviously both button gets detected.
can you provide the whole msg object items? Topic would by the key I guess. Just double click debug node, from dropdown select the whole msg object and post it with both buttons clicked again.
Maybe you will see the difference in messages, which could be used to the switch node.
Stepan
In the debug you can see that each button has its own topic eg button2 so you can use that.
