How to set a Room in Roomba?
I wish to set which room Roomba should clean. How do I setup a Room without the App?
Is it may either possible to advice roomba to move to a certain XY coordinate?
What have you tried so far?
What node are you using to control the roomba?
Does the node have an option to point at a room?
I use Dorita980 to controle my roomba.
Because I do not know how to beginn with, I was not able to do anything.
Well you can go to GitHub - koalazak/dorita980: Unofficial iRobot Roomba and Braava (i7/i7+, 980, 960, 900, e5, 690, 675, m6, etc) node.js library (SDK) to control your robot to see what commands you should be able to send but no guarantees.
Couple things to note,
  • I do not have a roomba so can't help you much more than I have and
  • the author of node-red-contrib-roomba980-fw2 has replied to a couple issues with the following:
I am not javascript developer, and have not enough time to work on this project. Real time map is an useful feature I also want to have, so I will leave this open, and maybe some day I will add this function, but I don't think I will finish it in near future.
If you can write code and have enough time and interest on this, you can do it yourself(fork & add function), and this is how FOSS works.
so you may be out of luck if something doesn't work.
Hi @zenofmud I also have an Issue on github about that. I had hope here in this forum someone has experiences in this.
