I want to create a ui button for dashboard that will perform the following function
On Click it should send value one and after release it should send value 0 like a push button
I don't believe you can. Only the click event is defined.
You will need to use a ui_template node to create your own button and add the appropriate event handlers.
I was able to create it in ui template node is there a way to add some delay between the events
"id": "0700c9ae90deec91",
"type": "ui_template",
"z": "7cfb14150528f229",
"group": "722e3efd98038504",
"name": "PSU 1",
"order": 15,
"width": 3,
"height": 1,
"format": "<button class=\"resetButton\" ng-mousedown=\"send({payload: 1})\" ng-mouseup=\"send({payload: 0})\" style=\"border-radius:20px;padding-top:7px;padding-bottom:7px; border: 1px solid #ffc65f;background-color: white;font-family:quicksand; margin-top:1px; \">Reset</button>\n<style>\n .resetButton:hover{\n background-color: #f9f9f9 !important;\n }\n</style>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": false,
"templateScope": "local",
"className": "",
"x": 870,
"y": 280,
"bf6296581a8d70e6"
"id": "722e3efd98038504",
"type": "ui_group",
"name": "Power Supply",
"tab": "0770fd16725d9e83",
"order": 9,
"disp": true,
"width": "23",
"collapse": false,
"className": ""
"id": "0770fd16725d9e83",
"type": "ui_tab",
"name": "power supply",
"icon": "dashboard",
"order": 10,
"disabled": false,
"hidden": false
