Hello there is a way to get the release event of ui button or is possible to get only the click
Luca
Dashboard is designed as a simple to use, no-code tool. So the simple answer is no.
You can however, create your own buttons using ui_template.
But if you want true, fine-grained control over your UI, you might be better off with something like uibuilder. The uibuilder client has a simple-to-use function designed to be used to easily send a msg back to Node-RED from an event handler:
<button onmouseup="uibuilder.eventSend(event)">Press Me!</button>
In the next release of uibuilder (v6.1), if you put the button inside <form>...</form> tags, you will even get back all of the form inputs without any further coding.
