How to solve HTTP - Request error - ERR_GOT_REQUEST_ERROR
Hi everyone,
I am facing a issue with a http simple request.
Doing a request to external websites it works perfectly but doing the same request internally i got a RequestError: Bad response: 503, statusCode: "ERR_GOT_REQUEST_ERROR". The same internal request works perfectly in the browser...
This works before, but after a global update of nodejs, and node-red... I'am now on node 18.13, node-red 3.0.2, it doesn't work anymore...
I spend all day searching for a solution throw the forum, and internet about a solution, nodejs request but nothing works... I clear cookies, flush DNS, configure proxy...
Does anyone is facing the same thing, have an idea ?
Thanks a lot.
.Christian
can you share more info?
  • What do you see in node-red error log?
  • Can you add a catch node linked to a debug node (debug set to show complete message)
  • Does this happen on a system running Node-RED 3.0.2 + nodejs v16 LTS?
  • Can export and share a minimal flow?
I'm using Node-RED 3.0.2 + nodejs v 18.13
        "id": "e59bf086a23fb8ba",
        "type": "tab",
        "label": "Flow 3",
        "disabled": false,
        "info": "",
        "env": []
        "id": "36583859466cde25",
        "type": "inject",
        "z": "e59bf086a23fb8ba",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 900,
        "y": 180,
                "0d8ecbe30e4d1be0"
        "id": "0d8ecbe30e4d1be0",
        "type": "http request",
        "name": "Request google",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "http://www.google.com",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 1080,
        "y": 180,
                "a2c1381f9557063f"
        "id": "a2c1381f9557063f",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1260,
        "y": 180,
        "id": "4b9586e4500d7869",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 900,
        "y": 220,
                "0d6da1e45fc2ed16"
        "id": "0d6da1e45fc2ed16",
        "name": "Local request",
        "method": "GET",
        "ret": "txt",
        "url": "vmprdpnlvzvcp01:8177/dataelements",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 1080,
        "y": 220,
                "69927ecbcd754145"
        "id": "69927ecbcd754145",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "x": 1260,
        "y": 220,
        "id": "d5b47bf1c3e90660",
        "type": "catch",
        "scope": null,
        "uncaught": false,
        "x": 940,
        "y": 360,
                "7953781a1fe651d6"
        "id": "7953781a1fe651d6",
        "type": "debug",
        "name": "debug 11",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1200,
        "y": 360,
OK,
I solve it removing the HTTP_PROXY params from the Environnement. Variables, then uninstall and reinstall NodeJs.
Thanks for your help.
