How to solve this problem when installing node-red on a raspberry pi 3 2015
Node.js is no longer current. I believe there is a parameter that will tell it to install v14 or v16 instead.
in this case what to do, my friend
I also get a certification
Run the script again with --node14 or --node16 added to the end
bash <(curl -sL -I https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered --node16)
No. At the very end of the thing you originally entered (not inside brackets)
bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered) --node16
Good friend
I put the same scrip and it yields this my friend
Run this to update installed packages first
sudo apt update && sudo apt full-upgrade
Then run the script again. If still no joy then which version of raspbian are you running?
That is not a version of rasbian
What does running cat /etc/os-release in a terminal show?
I can't read that on my phone, please copy/paste text, not screen image.
Did you do the update as suggested?
ok, bullseye is fine.
So I would suggest you fix the certificate error.
try the following 3 steps...
1
sudo apt-get remove curl
sudo apt update
sudo apt upgrade
sudo reboot
2
sudo apt-get install curl
sudo update-ca-certificates --fresh
3
then try the install script once more.
It is difficult to understand how the situation has arisen with bullseye. @JoanHc is this a fresh install of raspbian bullseye or did you upgrade from a previous version somehow?
I did it, but it still gives the same error.
did you do the 3 steps i outlined?
Thanks. It works on my Pi3. I can't solve this error for 2 weeks long. Now it's fine and ready to move on.
